glenandemm wrote:any pics and how did you prep them pal
If you click on my user name you can then click on user post to the bottom right and you will see the bits I have painted
These part where sanded to to get rid of some of the texture with 320 grit ,plastic primed , 2k highbuild primer followed with base coat then clearcoat this is with proper euquipment not rattle cans
