canbus wire colours ?
Postby cycleguy » Wed Aug 15, 2018 9:12 pm
Can anyone help me find out the colours of the
MS CAN high
HS CAN high
MS CAN low
HS CAN low
This is at the rear of the OBD11 PORT on a 2017 custom the OBD Port is not like the older vehicles which you can just put a tester on as these have big module on them
cycleguy
Re: canbus wire colours ?
Postby paul2012 » Thu Aug 16, 2018 1:01 pm
What is your intention :?:
Customs don't have a standard OBD11 port they have a GVM - Gateway Module A (Smart Diag Link Connector) instead.
There you will find the following networks :-
HS1-CAN - High Speed 1
HS2-CAN - High Speed 2
HS3-CAN - High Speed 3
MS1-CAN - Medium Speed 1
Playing around with those you may end up with U0146 Lost Communication With Gateway A - & a non runner :!: :!:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby cycleguy » Thu Aug 16, 2018 6:31 pm
paul2012 wrote:What is your intention :?:
Hi there Paul these are for a Directed DB3 all bypass for a clifford alarm install
cycleguy
Postby paul2012 » Wed Aug 22, 2018 3:57 pm
Directed DB3 is a immobiliser bypass for remote start & door locking :wink:
Unfortunately not compatible for Transit Custom according to manufacturer.
Module is aimed at the USA vehicle market.
If you buy one of these DB3 units online from Amazon / Ebay etc, what they don't tell you.
Only an AUTHORISED DEALER can flash the module with correct firmware for your vehicle. :!:
As from January 2017 Only Authorised Dealer's can log into Directechs site to download firmware & flash modules.
Loads of people including those who purchased the XpressKit XKLOADER2 were Pi**ed off over Directechs actions.
This is why you can by them cheaply starting from £28.
If installing yourself. Forget any Directechs modules, they are unusable - Unless your willing to spend $2000 per quarter to become a Authorised Dealer :roll:
paul2012
Return to Transit Custom
Users browsing this forum: schtall, sherwoodcycles
