by deeker » Fri Aug 17, 2018 9:40 am
Hi Folks, hope you can help with advice here. Autoglass recently replaced the windscreen in my 62 plate Transit Custom with equivalent screen (rain sensor and forward camera). The guy did a good job, checked the wipers were working and left. A week or so later when it rained the wipers came on automatically, out of sync and crossed in the middle. They got stuck for a moment, then separated both went to the fully up position, paused and then synchronised and worked normally. This happened a few times that week, so i asked Autoglass to check, but sods-law the wipers worked perfectly when autoglass returned. Since then the repeat the fault occasionally, sometimes on the sensor, sometimes on manual wash wipe. But irritatingly not every time. I've called the local dealer, but they never call back. I'm therefore looking for advise as to the cause and correction. Many thanks.
