by gregd72002 » Mon Mar 25, 2024 1:57 pm
Did you ever got it fixed?
I am currently battling similar issue. Not using the van that often nowadays but in good general condition so keen to keep it. Van regenerates every 20-80 miles or so, depending if city driving or motorway. Everything is standard, new injectors have not fixed the issue.
I am now thinking it is down to or EGR being sluggish, turbo actuator lazy, DPF passed its best days (but been cleaned professionally a year ago and deemed ok). Or some of the inlet pipes clogged with soot (too little air in), or letting unmetered air in (running too lean letting unburned fuel through).
Many ideas but don't want to start replacing things randomly. No error codes either. DPF regenerates fine and on idle the dpf pressure goes down to 6-10 mbar (6 when egr is open, 10 when closed) . After the 20miles driving in city, the dpf pressure reaches 16-25 mbar and then tries to regenerate agian.
