2003 mk6 transit crew cab tipper for sale
Sell all Transit Vans, Pickups, New and Old Here! [No Trade Ads]
Postby andy-m » Thu Dec 29, 2016 4:11 pm
my 2003 crew cab tipper for sale or swap for a mitsubishi l200 or a navara
2003 mk6 90
mot july 17
millage is 153890
brand new diesel pump 6 weeks ago cost of £960
new timing chain kit cot of £358,
had clutch and brakes fitted by last owner,
tipper work's 100% made me some good money,
just had new shocker top mount's fitted today 15/12/2016 with proof,
also as a crack in front screen but never bothered me,
few battle scares but it's a work horse. still as rear seats in, also a side lock box fitted but no key for it,
swap for 4x4, l200, mitsubishi warrior, navara with canopy's if it as one so i can remove when needed, something along them lines
more info on request
andy-m
Re: 2003 mk6 transit crew cab tipper for sale
Postby Guy88 » Thu Dec 29, 2016 7:39 pm
how much
Also watch out with the navaras, they keep snapping in front of tub
2005 Ford F250 Super Duty
1974 MK1 V8 ex camper
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby rimotu66 » Thu Dec 29, 2016 8:10 pm
Guy88 wrote:how much
And have a tendency to throw the odd rod through the engine block.
As for L200's, if it hasn't got a full service history including regular antifreeze changes best to steer clear, if you do get a L200 join the http://www.l200forum.com/ most of them are a great helpful bunch of lads and follow the 'remover egr and cooler' thread, common thought is that its the egr cooler going porous that causes the cylinder head failures, bottom crank pulley and balance belt needs changing every cam belt change as well so make sure that's all been done.
rimotu66
Postby tommypaul123 » Sat Jan 21, 2017 3:57 pm
Planing on buying a tipper for my yard man to drop off smal bits off scaffolding so won't use the tipper to tip my question is will it brake if I don't use it? And does it have to be working to pass mot thanks Tom
tommypaul123
Return to Transits For Sale
