2009 transit 2.4 115 Long/High
Sell all Transit Vans, Pickups, New and Old Here! [No Trade Ads]
Postby Aidanb » Sun Aug 20, 2017 1:32 pm
Hope some on here could give an idea of value?
As title, white, 230k miles, 11 months MOT, 2 keys.
It has no history, bought it 1st March last year at 178k. Serviced it within a couple of weeks and have serviced it myself 2-3 times since, it requires another service now. In my time with it, it has required: flywheel and clutch at around 185k, 2 complete hubs (new bearings, discs, and ball joints, easier to just bolt on all new than get it fitted) just before 2016 MOT, then left front hub again a couple of weeks ago (will need alignment) . I have no receipts for any work however.
This week will have new aux belt and outer crank pulley.
Intermittent electrical fault causing dashboard lights flashing in random order, loss of speedo, rpm and mileage, and then rough running. This comes and goes, may do it for a week then not for months.
Just today has an issue with starting, starter motor engages, turns engine over then a scraping noise, try a couple of times and it will start normally.
Otherwise starts fine but will need glowplugs when it gets cold.
Bodywork has a few dents but in my opinion is still presentable.
Advisory for discs and pads all round.
Has racking in the back. Tidy in the cab, drivers seat isn't too bad
Big towbar step but not wired in.
Tyres ok, 205r16 goodyear wrangler 110/108 all round, front left had wear to outside so has been swapped with a rear.
Aidanb
Re: 2009 transit 2.4 115 Long/High
Postby Aidanb » Sun Aug 20, 2017 1:42 pm
Couple of other points, rust spots above windscreen and on the sills in a few places.
Also, had brake pipes replaced at the same time as flywheel and clutch.
Both batteries new last year.
No key for slam locks. Next to the two rear number plates is a reverse camera, fitted but not wired in. Little screen included if I can find it.
Aidanb
Postby Mr RVM » Sun Aug 20, 2017 6:31 pm
Aidanb wrote:Hope some on here could give an idea of value?
Whereabouts is it and how much do you "need" for it........
Originally Restorationvanman
Mr RVM
Postby Aidanb » Sun Aug 20, 2017 8:35 pm
Ah thought my location was by my username, its in redditch which is a few miles south of birmingham.
Haven't really got a figure in mind. Would probably see what the best offer I can get is.
Aidanb
Postby Aidanb » Wed Jan 10, 2018 7:43 pm
Still thinking of selling...
Over Christmas had starter motor, glow plugs, SCV on the fuel pump (fixed fluctuating revs at idle), another crank pulley as the previous one was an aftermarket one that didnt run true, and oil and filter change (genuine filter and 5w30 fully synthetic).
It is on 233k miles now, had another van for a while so mileage hasn't gone up much since the summer.
If I could get £2000 for it i would sell, but otherwise will keep for a bit
Aidanb
Return to Transits For Sale
