THIS IS TANGO
SO....this is off the top of my head but I will update any info I miss out or need to correct
She is semi converted for race... i didn't do the conversion - not gonna
lie, its not great. It suited me fine as I put my tools in the back an then used the bit in the front to sleep on the odd occasion. Its got a skylight, VIPER alarm and central locking (key fob is temperamental and knackered - so i don't use it) I've got a replacement that I can chuck in if negotiated.
ROOFBARS NOT INCLUDED (going on my other van)
Got a switch charge relay fitted with wire to the back - leisure battery (but its knackered)
LED lights fitted in the back.
Had her since january last year. List below of work I've had done:
Vacuum pump seal
Rear brake calliper
New pads on the front
oil change
Re-welding of underside (£980 worth @ £35 p/h - ALOT)
Water pipe repair
something else that I cant remember.
MOT expires 24th APRIL 2018
Think its got around 120,000 on it. But cant remember for sure so i'll update this
I paid £900 and Ideally I wanted to get something similar back since I've spent ££££ in just over a year on her. But I know it doesn't work like that.
Was going to get i through the MOT to see if i could get some of that value back but then I realised I just couldn't handle it any more and not sure If i'm just wasting my dollar...
basically i think it needs some money spending on it to get it right. The work would include:
Oil leak (either chain cover seal or vacuum pump again)
Fuel filter change
EGR cleaning out
Glow plug maintenance
Two new front tyres
Brakes fixing (pedal goes to the floor - so either a line is broken or a cylinder has gone)
At the moment she has trouble starting, doesn't brake properly and guzzles fuel. All of which the above should sort out. But I just cant afford to spend any more money on it.
I'm based in South Wales/Bristol
If you are interested then make me an offer...PLEASE xx
