mk 5 swb semi high roof
Need a Tranny! Post Here!
Postby john yates » Mon Feb 23, 2015 10:34 pm
Sorry folks I strayed from the fold for a couple of years, looking for a way back in ! As above mk 5 swb semi roof would be good, £ 1000 for a straight van, white preferred
john yates
Re: mk 5 swb semi high roof
Postby transitandy » Thu Feb 26, 2015 8:47 pm
Welcome back m8 :)
Look in the ebay section as there's a nice turbo/auto one :wink:
Postby john yates » Sat Feb 28, 2015 10:13 am
Thanks for the heads up, nice van, shame it's an auto, I don't much like auto !
john yates
Postby davew2 » Sat Feb 28, 2015 10:55 am
If it ain't got leaf springs it in't a commercial
davew2
Postby john yates » Sun Mar 01, 2015 7:09 pm
Thanks Yes watching this one, only thing that would worry me is, it says it is fibre glassed halhway up the in sides ! What happens when you need to weld the rear corners which you will almost certainly need to do ?
john yates
Postby davew2 » Sun Mar 01, 2015 8:09 pm
Must admit i didn't read that. :oops: you can see it on the sides just looks like it has been boarded then glassed but you could do to know if the glass is direct to the floor if so it could be hiding a multitude of sins :cry:
davew2
Postby john yates » Wed Mar 04, 2015 11:47 pm
Re mk5 auto box, would it be possible to swap an auto to a manual box ?
john yates
Postby MinorMatt » Sat Mar 07, 2015 10:47 pm
Yes - its just put the gearbox, mount, crossmember, flywheel, clutch, clutch cable, pedal and propshaft in (with a flywheel)
You will also want the plastic bit that pop rivets to the floor round the gearstick.
It will have a permanent fault code logged (ECU light will be up for 5 secs when starting) but it won't affect it running
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Return to Transits Wanted
