mk3 mk4 mk5 parts inc mk5 cupholders
Postby turbotom » Fri Jun 29, 2012 11:04 pm
having a bit of a clearout,got
2 mk3 bonnets £30 each
1 mk4 bonnet £20
2 mk5 bonnets £20 each
3 mk3 front grills £15 each
2 mk4 front grills £15 each
8 mk3/mk4 front doors in various states of repair from damaged to mint £10-£30 each
4 mk5 front doors £25 each
mk5 dash complete £30
mk5 toureno tailgate complete near mint condition £45
mk4/5 toureno rear tailgate window light blue tint£10
mk4/5 toureno os rear window
mk3/4/5 door glass £5each
mk3/4/5 chassis cab rear windows 7 available £15 each
mk5 headlights approx 20 in all. £10 each
mk4 glass headlights £10 each
mk4/mk5 orange indicators £5 each
mk4/mk5 swb propshaft 2 available £30 each
mk4/mk5 lwb propshaft 3 available £40 each
mk3 extra long wheelbase prop £50
mk5 van towbar heavy duty £30
mk5 diesel radiator £20
mk5 van diesel tank 4 available £20 each
mk4/5 5 stud rear axle good diff £50
mk4/5 leaf spring got 3 pairs 1 is a single leaf type the other 2 pairs are from 150 swb vans £30 pair
mk4/5 5 stud steel wheels and tyres got loads some 2mm tread others near new £5-£15 each
mk3 twin wheel wheels and tyres again 2mm -near new £5-£20 each
mk3 twin wheel front axle passed mot ok £80
mk3 twin wheel rear axle type g ratio good diff £100
mk4 steering colums £20 each
mk5 front 2 seater bench £15
mk3 dash £20
mk4 dash £20
10 mk5 diesel gearboxes manual and electric speedo drives £50 each
1 mk5 auto box and other parts for conversion £80
mk5 swb load liner gen ford £20
mk5 swb low roof bulkhead with window £30
various 2.5 di engines £100 each
set of di pushrods £10
mk3 di lucas injection pump leaked diesel but worked well £30
set of 76 ps injectors from mk5 £20
2.5 di sumps 3 available £10 each
mk5 front bumpers 3 good ones available £15 each
quite a few other bits and bobs available.
can send via courier. willing to do a good deal if you want a number of parts.located northwich cheshire.
turbotom
Re: mk3 mk4 mk5 parts inc mk5 cupholders
Postby pamsy18 » Sat Jun 30, 2012 10:28 am
do you have the turbo / intercooler vents that are found on the front side wing of the transit MK5?
pamsy18
Postby Highlander250469 » Sat Jun 30, 2012 10:57 am
I'm after :
MK3 bonnet
2 x mint MK3 doors
and the MK3 twin rear axle its a G so 5.89 yes?
I will pick them up.
cheers
Stuart
Highlander250469
Postby johnbryden22 » Sat Jun 30, 2012 3:39 pm
Hi do you have the switch for front heated windscren on your mk5 or has anybody got one?
regards John
johnbryden22
Postby Simmie » Sat Jun 30, 2012 5:57 pm
How good condition is the mk5 dash?
Simmie
Postby phoenix » Sat Jun 30, 2012 6:53 pm
I'm after a couple of wheels with good tyres 195x14 to fit an ex BT MK 5 smiley. Am only around the corner from you in Lymm so could collect.
phoenix
Postby Pyro voodoo » Sat Jun 30, 2012 11:39 pm
What's the condition of he mk3 dashboard? And delivery to Leicester, thanks.
Pyro voodoo
Postby Rsturbo » Sun Jul 01, 2012 10:47 am
Hi
You have PM
Rsturbo
Postby turbotom » Sun Jul 01, 2012 6:00 pm
pamsy18 wrote:do you have the turbo / intercooler vents that are found on the front side wing of the transit MK5?
sorry dont have one of those although do have my eye on a mk5 turbo that hasnt moved for about 3 years after failing its mot test. will advertise on here if i get the chance to buy it.
turbotom
Postby turbotom » Sun Jul 01, 2012 6:03 pm
Highlander250469 wrote:I'm after :
MK3 bonnet
2 x mint MK3 doors
cheers
Stuart
hi the mint pair of doors sold within about 20 mins of posting the ad but i do have several other front doors including some very good ones i will pm you my phone number.
turbotom
Postby turbotom » Sun Jul 01, 2012 6:06 pm
johnbryden22 wrote:Hi do you have the switch for front heated windscren on your mk5 or has anybody got one?
regards John
hi sorry i dont have one of those. if they are the same as mk5 escort i probabaly have one from a mk5 escort.
turbotom
Postby turbotom » Sun Jul 01, 2012 6:08 pm
phoenix wrote:I'm after a couple of wheels with good tyres 195x14 to fit an ex BT MK 5 smiley. Am only around the corner from you in Lymm so could collect.
hi yes i have some 195x14 wheels and tyres ill pm you my number and im in highlegh quite a lot so we could meet up there if thats easier?
turbotom
Postby turbotom » Sun Jul 01, 2012 6:10 pm
Simmie wrote:How good condition is the mk5 dash?
hi its in good condition if you would like a pic pm me your email address and ill send you some pics in an email.
turbotom
Postby turbotom » Sun Jul 01, 2012 6:14 pm
Pyro voodoo wrote:What's the condition of he mk3 dashboard? And delivery to Leicester, thanks.
hi the best mk3 dash i have is very good but it does have a bit of overspray on the sides that should come of with some thinners there is also a toggle switch below the drivers side vent.
delivery would be about £20 via courier.
turbotom
Postby Chrisbapple » Mon Jul 02, 2012 7:37 am
How much for the lowest miles MK5 2.5Di engine?
Cheers
CHris
First Transit: Mk5 HiCube LWB
Chrisbapple
