breaking smiley 2000 xlwb minibus
Re: breaking smiley 2000 xlwb minibus
Postby JOHNPINTO » Fri Mar 08, 2013 3:23 pm
:D hi,pm'd u about the tuburlar rear door checks,cheers john pinto.
JOHNPINTO
Postby Choppergeoff » Mon Mar 11, 2013 2:00 pm
Hi Tony.
PM sent re- door pillars.
Cheers Geoff
I don't do Standard and I don't do Normal...whatever that is
[url]Past vans [/url]1966 Mk 1 V6 3.0ltr Camper. 1982 Mk 2
9 or 10 Mk 3/4/5's
current ...Customised SHR LWB twin SLD Door Chopped roof Turbo D
Choppergeoff
Postby JOHNPINTO » Mon Mar 11, 2013 9:27 pm
hi,i assume you did not get my last pm,i am after the rear door looms assuming the bus has two rear doors and not one,the looms are carried between the door and frame by a strong plastic tube to protect the looms,i need the tubes and the plastic securing inserts at each end which prize out with a flatblade screwdriver,and if there are metal plates that fix on so the tubes cannot be cut whilst the doors are closed i will have these aswell please,will posting be ok please,new pm sent aswell,regards john pinto. :D
JOHNPINTO
Postby turbotonyo » Tue Mar 12, 2013 8:33 pm
Ian1 wrote:Have you got the coat hook that fixes to the door pillar behind the drivers door please? Or even better, two hooks?
Thank you,
Ian
hello again ian, yes i've got a couple of coat hooks, pm me your address and i'll send them you,
turbotonyo
Postby turbotonyo » Tue Mar 12, 2013 8:35 pm
JOHNPINTO wrote:hi,i assume you did not get my last pm,i am after the rear door looms assuming the bus has two rear doors and not one,the looms are carried between the door and frame by a strong plastic tube to protect the looms,i need the tubes and the plastic securing inserts at each end which prize out with a flatblade screwdriver,and if there are metal plates that fix on so the tubes cannot be cut whilst the doors are closed i will have these aswell please,will posting be ok please,new pm sent aswell,regards john pinto. :D
hello john i've now got your pm, i'll check tomorrow and get back to u, (i forgot today! :oops: )
turbotonyo
Postby turbotonyo » Tue Mar 12, 2013 8:36 pm
fordmad82 wrote:hi pal what colour is it and do you still have the drivers and passenger doors
its white and yes i still have both doors complete
turbotonyo
Postby fordmad82 » Tue Mar 12, 2013 9:55 pm
hi.how.much.and.could.pick.up.friday.thanks
fordmad82
Postby turbotonyo » Thu Mar 14, 2013 9:47 pm
fordmad82 wrote:hi.how.much.and.could.pick.up.friday.thanks
£20 each complete except mirrors.
turbotonyo
Postby turbotonyo » Thu Mar 14, 2013 9:48 pm
hello again john, i'm sorry but i totally forgot today again i've been that busy! but i'll have a look tomorrow for definite!
turbotonyo
Postby fordmad82 » Fri Mar 15, 2013 12:00 am
when could i pick up thanks
fordmad82
Postby turbotonyo » Sat Mar 16, 2013 9:27 am
fordmad82 wrote:when could i pick up thanks
pm sent :)
turbotonyo
Postby turbotonyo » Sun Mar 17, 2013 10:13 am
hello again john, yes the van has the plastic covers but doesn't have the metal covers over, £10 posted if u want them mate?
turbotonyo
Postby v6petrol » Wed Mar 20, 2013 8:23 pm
is the bus a turbo DI or std aspirated
v6petrol
Postby turbotonyo » Fri Mar 22, 2013 10:48 pm
v6petrol wrote:is the bus a turbo DI or std aspirated
it was turbo but now naturally aspirated.
turbotonyo
Postby turbotonyo » Tue Mar 26, 2013 3:43 pm
afireinside- wrote:Hi mate I'm after full turbo engine with all the bits to convert my di to tdi can collect also.
What's best price? Pm me if you prefer cheers
hello mate, sorry about delay in replying, i have most of the parts to convert to turbo, including sump, turbo and manifold, exhaust manifold, rocker cover, oil cooler and probably more. open to offers for the full lot, but i was thinking of keeping them for my next Di, so i wont let them go silly cheap but i'm not greedy. in my opinion anyway lol :?
turbotonyo
