as title
originally bought the vehicle from Doncaster and drove her back 250 miles to Kent. Drove sweet as a nut on the was home.
ripped the fibreglass body off and fitted in the back of the cab and that's as far as I got, got too much going on at the moment so decided to split it.
what im offering here is
3.5 v8 engine
automatic box
complete exhaust system
all water pipes
radiator
all the air con pipes radiators etc
fuel tank
cables
gearshifter
pedal box
floor mat
clocks
120l lpg tank and all necessary fitings vaporizer etc
basically you can have every single last bit you require from the old girl apart from the air suspension pump and back axle
you are more than welcome to come hear it running, although it has no fan belt on at the minute as ive fitted a new water pump, also this has had a full set of plugs and leads
looking for £500 the lot or near offer, more than welcome to help remove on the day
