mk6 clear out, starting to list on ebay
Postby gavcarter » Thu Jan 21, 2016 1:51 pm
Having a clear out, got hubs, rear axle, all springs, wiring harness, clocks, dash bits, gearbox, fuel pumps, engine, turbos etc etc
Pm or reply to thread for any queries, loads of stuff to get rid off
gavcarter
Re: mk6 clear out, starting to list on ebay
Postby knighty1981 » Thu Jan 21, 2016 2:14 pm
have you got any of the rear door top latches ?
the bit that bolts to the van and sticks out with a loop for the door to latch onto ?
I already bought a pair, but they've got walk about :-(
knighty1981
Postby gavcarter » Thu Jan 21, 2016 10:25 pm
No sorry, mainly interior and mechanical bits left now
gavcarter
Postby spudmab » Sat Mar 19, 2016 4:35 pm
Have you got any air-com parts, need the round bottle thing, rad thing, pipes.
spudmab
Postby gavcarter » Sat Mar 19, 2016 5:25 pm
Sorry van didn't have air-con
gavcarter
Postby karl » Sat Mar 19, 2016 5:33 pm
i have what you need top and bottom latches
karl
Tranny Lover!!!
Postby Jayseller » Fri Mar 25, 2016 1:57 am
single or double wheel axle?
Jayseller
Postby gavcarter » Fri Mar 25, 2016 10:32 am
Single, fwd, no abs
gavcarter
Postby Jim Archer » Sun Mar 27, 2016 9:54 am
Twin batteries?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby gavcarter » Sun Mar 27, 2016 3:35 pm
Single, kept the battery for spare
gavcarter
Postby Jpv85 » Mon Jun 13, 2016 8:10 pm
Do you have a 2.0 tdci engine? The engine i need to replace is in a 125t280 mk6. Cheers
Jpv85
Postby gavcarter » Mon Jun 13, 2016 9:12 pm
Only one I have is a BARE engine and needs a timing kit putting on it
gavcarter
Postby Jpv85 » Thu Jun 16, 2016 4:07 pm
When you say bare engine, what would it need? I might be able to transfer parts from the original broken engine.
Jpv85
Postby gavcarter » Thu Jun 16, 2016 5:08 pm
Timing kit and fuel pump, I raided it for a fuel pump, and used locking pliers and drill bits to set the timing. The youngest pulled all the drill bits out when we were tidying up. I think to be sure it goes back right, the head will have to come off, be retimed and the chain and tensioners all putting back on, I've stuck it in a corner as a job for another day lol
gavcarter
Postby gavcarter » Thu Jun 16, 2016 5:16 pm
I still have all the timing parts with the engine and they didn't seem in bad condition, alternator and starter have been taken off, 99% sure the water and steering pump is still on. It is a bit of a challenge if I'm honest, but worth it, its done just over 100,000 miles, was on a 75ps and its been well looked after so I'm told, it sounded nice when it drove in.
I do need the space so if you can collect it, £100 will shift it - or will swap for transit stuff... Nice mk7 drivers seat, new brakes, repair panels, decent headlights anything that helps the project along really would be considered
gavcarter
