Transit Smiley Epic pump,ecu,Throttle Peddle etc
Postby Kev1000s » Sat Apr 16, 2016 12:57 pm
Removing from Transit Smiley 150td late registered in 2002, Good working order , you will get Pump ,ecu ,peddle and any other bits removed to do with epic system.This is in my vehicle running only removing as i want to fit a intercooler and 130ps injectors ,so will be fitting bosch manual pump so i can up the fueling. £200 , i am willing to post at your expense, or you are welcome to collect off me.
Kev
Ford FDS 2000
52 plate , Smiley 150lwb ,Td,Ex police :)
1996 Smiley 100 ,Td-Intercooled , lowered 50mm,mk6 wheels,lsd 4.11..
Kev1000s
Re: Transit Smiley Epic pump,ecu,Throttle Peddle etc
Postby Kev1000s » Wed Apr 27, 2016 9:53 am
Will take £150 for this , will need to remove from van..
Ford FDS 2000
Kev1000s
Postby Tigs » Wed May 04, 2016 12:52 pm
U could jus be my saviour here. I'm looking for an epic fuel pump plug that plugs into back of fuel pump. Mine has corroded and need that part. If no one has the pump and parts that would be gratefully bought. I have an auto box and am disabled. Broke down 3 days ago and now stuck at home until I can source the parts. If you do have the plug and I can have it we would need some of the loom it is on so we can splice the new plug into exciting loom.
Fingers x this end for any help
Ali
Tigs
Postby MinorMatt » Wed May 04, 2016 1:19 pm
I have several epic engine looms ;)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Kev1000s » Thu May 05, 2016 9:01 am
i still have epic pump fitted to van and won,t be cutting the loom. I should take Matt up on his offer. :)
Ford FDS 2000
Kev1000s
Postby Tigs » Fri May 06, 2016 12:12 pm
I've taken a pic that u posted of fuel pump. Will show my mechanic it as it looks like the same one on mine. And will pay all expenses associated to posting it to me. And get in touch with Matt to do a new loom. Hopefully this will all solve problems.
Thanks again for help
Ali xx
Tigs
Postby Kev1000s » Fri May 06, 2016 5:31 pm
ok ,let me know and i will remove ....Kev :D
Ford FDS 2000
Kev1000s
Postby Kev1000s » Thu May 26, 2016 8:32 am
No longer for sale...... :(
Ford FDS 2000
Kev1000s
Postby Kev1000s » Wed Jul 20, 2016 7:32 am
Complete set up for sale off another van i am breaking for spares including loom £150... :D
Ford FDS 2000
Kev1000s
