Mk3/4/5 engine, gearbox steering, wing
Postby MinorMatt » Mon Jul 25, 2016 8:57 am
This is a last chance before they go on ebay. To be collected from Haywards Heath (Sussex).
70PS 2.5Di. 112K from an X reg 80. Ran well. Has all ancillaries except starter and could be dropped straight in. £200
MT75 Gearbox - From the same van. Again no issues with it - £50.
PAS Rack, Pump, Pipes etc (no track rod ends) - will fit all mk3/4/5 diesels, and mk4/5 petrol if you make an adaptor (Dieselhead123 may still be able to supply one?). - £120
Complete steering column from above van, inc steering wheel, indicator & light switches, UJ and ignition barrel/key - £25
New old stock Mk3 Passenger front wing. Genuine ford panel without repeater hole. Some surface rust but not too bad £50
As said these will be going on ebay later this week so if anything is of use to you shout up. I will not be taking things to TM this year unless specifically wanted
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Mk3/4/5 engine, gearbox steering, wing
Postby BROWNYS V6 » Fri Jul 29, 2016 9:08 am
matt have u got a pic of the wing ?
can u text it to my phone if its still available
cheers :)
BROWNYS V6
Postby MinorMatt » Fri Jul 29, 2016 8:38 pm
Errm its a new wing. I had a load of them, and I have pics but not sure if I have a pic of the actual wing!
I will text you
93 L GL Minibus
Postby MinorMatt » Fri Jul 29, 2016 8:42 pm
I will text you
93 L GL Minibus
