I have a full length Rhino roof rack with rear door ladder in good condition for a short wheel base, low roof mk6 & 7 Transit. Only seen light use to hold a Canoe.
I lost one of the M8 bolts that joins the sections together. You can get a new one easily and cheaply from screwfix.
One of the neoprene pads that sits between the mounting bracket of the ladder and the door I could not get off in one piece. You could trim a piece of rubber sheeting to do the same job.
Open to offers around £100 located near Woodbridge Suffolk. My mobile is 07710433939.
Many thanks
Edd
