mk7 twin wheel rear axle 6 speed
Postby greenmini » Thu Sep 08, 2016 7:58 am
6 speed twin wheel pickup mk7 axle, removed from failed recovery truck project, diff cover plate dry, low 70ish thousand miles, complete as it was dropped off the truck, good calipers etc. 300 can deliver local to Edinburgh, if not would happily post at your expense graham 07808701361
greenmini
Re: mk7 twin wheel rear axle 6 speed
Postby nitram2204 » Thu Sep 08, 2016 10:07 am
do you know what ratio it is ?
Nitram
nitram2204
Postby greenmini » Thu Sep 08, 2016 11:06 am
pass any ideas how to identify? came off a pickup/tipper
greenmini
Postby t2myd » Thu Sep 08, 2016 7:12 pm
Should be a tag on diff plate , or put reg off what it came off into ford etis
Transit vantastic !!!!!!
t2myd
Postby karl » Thu Sep 08, 2016 7:15 pm
tipper will be a a high ratio diff due to carrying a load weight :D
p.s ETIS isnt always correct as i have found out over the past
karl
Tranny Lover!!!
Postby t2myd » Thu Sep 08, 2016 10:02 pm
Not all tippers are , I've a 3.73 axel on a mk7 bought new lot of euro 5 are 3.91 ratio
t2myd
