Mk3/4/5 parts
Re: Mk3/4/5 parts
Postby Riggard » Tue Dec 12, 2017 5:56 pm
Hey, my ford nugget campervan has a eberspacher d3lp. It turns out that the ECU (part number 25 1688 50 00 37 R4 ) is broken, eeprom error. Do you happen to have one of these lying around?
Riggard
Re: Mk3/4/5 parts
Postby Karlo65 » Tue Dec 12, 2017 8:16 pm
Need a windscreen for my ambulance can you help
Karlo65
Re: Mk3/4/5 parts
Postby Cherrycoketurbo » Fri Apr 06, 2018 7:10 pm
Hi mate, u got a mk 4/5 5stud rear axle? Bare or we bits on, anything? My dif gone from humming abit to 3 cats yowling thier heads off in 1 day!! Mine s a 94 swb new gen, either 80 or 100 so owt ll do, cant be mk 3 tho, not wide enough I think
Cherrycoketurbo
Re: Mk3/4/5 parts
Postby MinorMatt » Wed Apr 11, 2018 9:58 pm
Not got an axle... but may have a diff
96 N 120 Turbo'd DI SWB Low
97 P 150 76PS Di SWB low ex essex police
Lucas laser 2000 & IDS onwner
Re: Mk3/4/5 parts
Postby ssmc2010 » Thu May 03, 2018 2:42 pm
hi do you have a mk3 rear diff or full axle with diff
ssmc2010
Re: Mk3/4/5 parts
Postby MinorMatt » Thu May 10, 2018 7:38 pm
No mk3 diffs or axles...
Re: Mk3/4/5 parts
Postby bourg1664 » Fri May 18, 2018 5:57 pm
Hi Matt new here I have a mrk5 1995 2.5td/lhd/red I am after power steering pipes the ones that have the threaded bits at the ends with a rubber olive I could even do with just the end bits to make the up with compression joints
Hoping you can help
REGARDS Jack
bourg1664
Re: Mk3/4/5 parts
Postby MinorMatt » Sat May 19, 2018 5:25 pm
Hi Sorry, but don't have any PAS stuff
