night heater
night heater
Postby jonnyivy » Tue Oct 18, 2016 6:30 pm
Hi folks,
just bought this mk7 transit and its an ex- eon van.
Inside the rear there is a heater system which I gather would be to keep the engineers warm while they worked in the back (workshop).
Its powered by the diesel from the tank,...so there's a small pump,.. a thermostat and a blower.
Anyone know if its worth selling and if it would be worth the hassle of dis-connecting it ??
Maybe some members here would buy it for a camper conversion ?
Jonny
jonnyivy
Re: night heater
Postby andz327 » Tue Oct 18, 2016 7:21 pm
Is it fully working??
andz327
Re: night heater
Postby mistericeman » Tue Oct 18, 2016 7:39 pm
Deff worth selling IF it's complete and working... eberspacher diesel heaters often fetch £300/£400 on eBay in working condition...
search out the model (usually on label on side of unit) then search sold items on eBay for an idea of value
mistericeman
Re: night heater
Postby jonnyivy » Tue Oct 18, 2016 8:20 pm
yes its still working,.. there's a switch on the dash to fire it up,... there's no broken parts as far as I can see,... there sure is a label on the side,... J. Eberspacher Esslingen,...Airtronic,...2.2 kw....
Never thought it would be worth anything,... well its not worth anything to me ....
Thanks for that info...
jonnyivy
Re: night heater
Postby walt1984 » Tue Oct 18, 2016 8:23 pm
Try it , it should run on high until up to temp then drop down on to low . There should be no or little smoke from exhaust. Its getting to time of year wher they make more money.I'd keep it personally.
Sent from my HTC One S using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Re: night heater
Postby jonnyivy » Tue Oct 18, 2016 8:30 pm
I will try it out, see if it does what you say,... the thermostat looks good too,.... I'm just wondering how big a job it will be to remove it,...I only keep / transport lawntractors and mowers in the van so not much use.
On another note it also has a secondary alternator mounted perfectly under the original on the bottom of the engine,... this is to run a converter to feed the 220v sockets mounted at the back of the van. I'm going to disconnect this as well as I dont want it either. Need to look see if these are desirable parts too ....
jonnyivy
Re: night heater
Postby 68 beeper » Tue Oct 18, 2016 8:33 pm
Hi there
How much are you looking for it please
68 beeper
Re: night heater
Postby 68 beeper » Tue Oct 18, 2016 8:34 pm
Hi there
68 beeper
Re: night heater
Postby jonnyivy » Tue Oct 18, 2016 8:42 pm
I will try it out tomorrow and let you know if it all works first,....I'm open to offers as long as its not too big ajob to remove... Thanks
jonnyivy
Re: night heater
Postby gatecrasha » Tue Oct 18, 2016 10:09 pm
I'd be interested in this if your definate about removing it.
gatecrasha
Re: night heater
Postby andz327 » Fri Oct 21, 2016 4:11 pm
How many rubles??
andz327
Re: night heater
Postby jonnyivy » Fri Oct 21, 2016 8:09 pm
Have sold it now ,...thanks for the opportunity to sell on here...
jonnyivy
