Fog lights, led lights plus lots of other stuff...
Postby dirtydog » Sun Jan 15, 2017 6:09 pm
Right having a bit of a clear out in the garage
Prices include postage to mainland uk
Chrome reversing camera, never fitted, tested and working £5
Reversing camera never fitted, tested and working £5
Reversing camera never fitted tested and working £5
4.3 inch monitor, never fitted, still has cover on the screen £5
Ring roadrunner round fog lights, brand new still in their box £18
dirtydog
Re: Fog lights, led lights plus lots of other stuff...
Postby dirtydog » Sun Jan 15, 2017 6:19 pm
Ring illumnator3 projector fog lights new in box £35
37mm gauges, oil pressure, oil temp and water temp, fitted briefly in my xr2, new oil temp and pressure sensors plus adapters, water temp sensor is missing £25
Stereo fascia adapter with loom and steering wheel controls compatible with a sony had unit £20
Small lights £5 for both packs
Led switches with missile type covers there are 3 altogether £5
dirtydog
Postby robbie.cee » Sun Jan 15, 2017 6:44 pm
Ill have the monitor . Black rear camera and the 3 illuminated switches pls can ypu pm me payment details pls .
Cheers
Rob
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Jan 15, 2017 6:45 pm
It was the last of the black cameras btw . looks like it can be moved in the socket
Had
MAKE IT FIT
robbie.cee
Postby dirtydog » Sun Jan 15, 2017 7:06 pm
The last black camera is a fixed lense one, needs to be mounted under something.
I'll see if I can find a link to one on ebay
dirtydog
Postby dirtydog » Sun Jan 15, 2017 7:09 pm
dirtydog
Postby robbie.cee » Sun Jan 15, 2017 7:27 pm
All good mate pm me your details ill send you the money. 15 quid yes
Had
MAKE IT FIT
robbie.cee
Postby dirtydog » Sun Jan 15, 2017 8:25 pm
Will be adding more stuff later tonight
dirtydog
Postby robbie.cee » Sun Jan 15, 2017 8:34 pm
Cool cant wait!
Had
MAKE IT FIT
robbie.cee
Postby dirtydog » Sun Jan 15, 2017 8:53 pm
2 led toggle switches, one red one blue £3 for both
Maxi fuse holder £3 has a 25amp fuse with it
Amber strobe lights, one is missing a nut and bolt, tested and working £4
Led lights, never fitted, some scratches from being chucked in a box with loads of other stuff £4
Round led lights, never fitted. Tested and working. £5
dirtydog
Postby dirtydog » Sun Jan 15, 2017 9:01 pm
Prism blue led strips £5
Round fog light switch £1.50
Led interior light, works but has one dead led in it and a few surface scratches £2
That's it for today, I'm pretty sure I've got some other bits and pieces laying around including some mk5 dash switches
dirtydog
Postby dirtydog » Sun Jan 15, 2017 11:47 pm
Mk5 heated mirror switch, brand new £10
dirtydog
Postby jonochap » Mon Jan 16, 2017 7:14 pm
Robbie mate, is it too late to bounce the silver camera into your post bag if I can get a fiver to you?? :)
Owner of not so troubled puk :)
jonochap
Postby jonochap » Mon Jan 16, 2017 7:15 pm
Or I can bounce a fiver to you DD and you can put it in with Robbies stuff? :)
jonochap
Postby dirtydog » Mon Jan 16, 2017 7:52 pm
I can stick it in with robbies stuff no problem
dirtydog
cron
