FORD TRANSIT MK 7 .... SEE ADD
Postby billybun » Thu Jan 26, 2017 9:37 am
FORD TRANSIT MK 7 2006 2.4 REAR WHEEL DRIVE ...... 6 SPEED GEARBOX(3 BOLTS ON REAR )., FULL SOLID FLYWHEEL CLUTCH KIT, FITTED LESS THAN A MONTH CAN CLEARLY BE SEEN BY CONDITION, , GEAR CHANGE CABLES, GEARSTICK (DASH TYPE ). WATERPUMP AND VAC PUMP, ECU AND ENGINE BAY LOOM WITH FUSE BOX COMPLETE WITH FUSES/RELAYS , DOWNPIPE, STARTER MOTOR,... DIESEL PUMP , ALTERNATOR,DASH CLOCKS , EVERYTHING IN PERFECT WORKING ORDER , ALL ONE JOB LOT,SO NO OFFERS AS ITS A TOTAL STEAL AT £295. ..... CAN COLLECT FROM BIRMINGHAM JUNCTION 6 0F M6 THEN ABOUT A MILE, OR 7 MILE FROM JUNCTION 21A OF M1 LECIESTER....... CAN ONLY COLLECT EVENINGS OR WEEKENDS ....
billybun
