Catalictic Heater For Sale
Postby BootsBoots » Thu May 18, 2017 8:43 pm
Hi All,
Due to a change of plans I have the following for sale,
An AKS MIDICAT butain/propane 1900watt gas heater in good working order.
Brownish metallic hammered finish, size (in old money) 15.5h x 13w and a couple of inches deep.
Has the on/off knob on the lower left had side, gas in bottom left with a 'foot' bottom right to enable the unit to be 'free standing' when used with a stand, not supplied.
Can be wall mounted on a suitable surface and plumbed in with suitable fittings or fed with correct type of flexible pipe when free standing.
Catalictic heaters produce heat by the gas causing a reaction when lit with a type of 'matting' so there is little or no flame when in use.
They also produce little to no fumes unlike a gas fire with flame(s).
50 GBP collected, postage at cost.
Boots
I'm M6, J34 @ Lancaster. Lancashire. Brews always available.
BootsBoots
Re: Catalictic Heater For Sale
Postby BootsBoots » Sun Jan 21, 2018 10:52 pm
Hi All,
Still available.
Boots
BootsBoots
