90's 5 stud transit discs and pads
Postby Chuggy » Tue Feb 06, 2018 4:46 pm
A friend bought 2 new front discs and pads and never fitted them, from Eurocarparts I think.
Brand is Eicher, they should fit most 90's transits with 5 stud wheel fixing, £40 collected from Tring, Herts HP23, or £50 posted
Discs are the same as this https://www.eurocarparts.com/ecp/c/Ford ... a74&000027
Dimensions:
Diameter 254mm
Centering Diameter 78,5mm
Height 43mm
Pads are the same as these. https://www.eurocarparts.com/ecp/c/Ford ... d86&000036
Dimensions:
Width 138.8mm
Height 64.2mm
Thickness 19mm
Chuggy
