Cab marker lights.
Re: Cab marker lights.
Postby wexican » Tue Jul 03, 2012 4:09 pm
Are the wires already in the A pillars to fit cab lamps??
wexican
Postby ake » Tue Jul 03, 2012 4:47 pm
No, no wires in pillars, to do it correctly on a MK 7 they should be connected in with the number plate lights, so they do not interfere with the parking lights
Postby stephenferguson » Tue Jul 03, 2012 7:17 pm
anyone know if the wring plug is up in the roof on a mk6 semi high? mine is 100ps so has the leccy windows and mirrors etc fancy two cab markers on my roof now!!
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby ake » Tue Jul 03, 2012 7:50 pm
stephenferguson wrote:anyone know if the wring plug is up in the roof on a mk6 semi high? mine is 100ps so has the leccy windows and mirrors etc fancy two cab markers on my roof now!!
No wires on vans, only chassis cabs, but rear light cable go up a pillars, so easy to tap in
Postby wexican » Tue Jul 03, 2012 8:57 pm
ake wrote:No, no wires in pillars, to do it correctly on a MK 7 they should be connected in with the number plate lights, so they do not interfere with the parking lights
I've already changed the orange side markers for LED ones- no problems.
If I go LED on roof what problems would they cause if wired into tail or side lights?
wexican
Postby ake » Wed Jul 04, 2012 7:06 am
Won't cause any issues, just they will come on with parking lights, but they shouldn't
Postby stephenferguson » Wed Jul 04, 2012 8:04 pm
Cheers Ake, dont know why i didnt think of that!!
stephenferguson
Postby Rumble bee » Thu Jul 05, 2012 9:06 am
Just an update on these.
I bought the 'bolt on bits' led markers but as the leds are angled inside the housing they aren't very bright when mounted flat on my roof. They would suit a medium roof better mounted on the angle rather than the flat top.
Also picked up some ford tipper markers, as the tipper roof has flat parts profiled into it to take the markers I will have to shave down the markers to fit my roof. Also have to find some led bulbs for them too.
I also bought some of the white led half circle marker lights (if that makes sense) and knocked out rear number plate lights and stuck them in there to light up my plate. Mines a lift up rear door, so has the bulbs in the big handle.
Chris.
Rumble bee
Postby jd-lee » Sun Jan 20, 2013 12:18 pm
have u tried fitting these yet?
do u have to shave stupid amounts off? and do u think it can be done easily?
what about the thread for the bolt?
cheers rumble
2007 Transit GLX 130 SWB - Now reprogrammed ECU to 140bhp and retuned to 170bhp by the man himself... vantuner - upgrade to six speed and has All the toys ;-)
Custom made front grill
jd-lee
Postby Rumble bee » Sun Jan 20, 2013 12:55 pm
Are you stalking me :shock: im sat here now doing them :lol:
Rumble bee
Postby jd-lee » Sun Jan 20, 2013 2:22 pm
:lol: outside in the bush 8)
Talk me through what ur doing? I can't quite see past the twigs
jd-lee
Postby Rumble bee » Sun Jan 20, 2013 3:55 pm
Few pics,
Split the lights, bottom half wont fit my roof
So i just going to use the top half and use a rubber seal to seal it to the roof,
New bulbs, cree ba9 i think,
Old,
New,
Fitted the bulb,
Then screwed the lights to the van with a seal and connected them onto the wires i'd left from last time,
The wires I connected on to go up and across the roof lining to power the rear side lights.
It was a while ago so cant remeber which colour wire I connected on to. When i originally put the wires in, I just pulled the rear light off the back of the van to find which colour wire it was, then found it in the head lining.
Only took me 6 months :lol:
Rumble bee
Postby jd-lee » Sun Jan 20, 2013 5:09 pm
I like them mate. I been looking at these Cree bulbs. Thinking of trying the headlights cause there a projector lens and ment to give a hid look.
Anyone tried them?
jd-lee
