Fwd Transit 280 di keeps cutting out
Postby Simtrike » Sun Feb 03, 2013 8:03 pm
Can any one help I Have a 51 plate transit fwd 280
It runs and tics over super but as soon as its warm it and you rev it up it will cut out the glow plug plight flashes as it dies but it will start straight back up and tic over but die if you rev it
I have stripped the front off the van to see if there is any thing that is visible I found a few wires at the top off the engine
That had rubbed and chaffed I have sleeved them but it still cuts out when it gets warm I have noticed that the oil pressure switch plug is snapped of not sure if this would cause this issue
all filters have been changed and new air filter
Please could some one help
Simtrike
Re: Fwd Transit 280 di keeps cutting out
Postby ake » Sun Feb 03, 2013 11:21 pm
Water pump failing ?
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
Or is it something worse?
Postby Simtrike » Mon Feb 04, 2013 8:54 pm
Right got the starter motor off does any one know we're abouts the breake in the loom happens or would it be recommended to wrap every wire to be on the safe side
Simtrike
Postby Phil_G » Tue Feb 05, 2013 8:37 pm
glowplug light flashing is indicative of a fault being logged by the ECU - have you had this scanned for codes?
Phil_G
Postby Simtrike » Wed Feb 06, 2013 12:16 am
I have had 3 people come and try all get comunication error
I have a mobile diagnostic come out tomorrow so will post the codes as long as he can do it
Hope so any way
Simtrike
Postby Phil_G » Wed Feb 06, 2013 12:29 am
something's rattling around in my mind that someone I met once had problems with the diagnostic socket being traced back to a fuse in the engine bay.. which one and why it had popped, i don't know, but that might be worth a look
Phil_G
Postby ake » Wed Feb 06, 2013 7:31 am
ake wrote:Water pump failing ?
Has this been checked?
If the engine overheats due to a failing water pump the ecu will shut it down
Postby Simtrike » Wed Feb 06, 2013 11:44 pm
No does not over heat have had it ticking over for about an hour sounds sweet but as soon as you rev it up glow plug light flashes and cuts out then you can start it straight back up and will tic over all day unless you rev it
I have a mobile diagnostics bloke coming out Friday to read codes but will make sure it is warm before they come as like I say it runs and revs fine until at normal driving temp
But will check the fues box tomorrow will keep updating progress and post the fault if I find it but would be very graitfull for any more suggests it idears what it could be
Simtrike
Postby yyahtzee » Thu Feb 07, 2013 4:44 pm
I had a similar problem with the alternator cable which is in the engine loom. It had been chafed through and was arcing against the engine this then shuts the ecu down due to the voltage drop. I ended up pulling the whole loom of to find it and the were a few other chafes that were nearly through.
yyahtzee
Postby Simtrike » Thu Feb 07, 2013 8:15 pm
Thanks will check that tomorrow
Fingers crossed diagnostics at 8 In the morning and will give up some codes as I don't want to have to go throu a proses of alimunation as it will start to get expensive but will keep posting and will add the codes tomorrow
Thanks again to all of you for you posts
Simtrike
Postby Simtrike » Fri Feb 08, 2013 12:55 pm
Right got codes
P1665
P1563
P1664
P0335
Can any one help
Simtrike
Postby angeleye » Fri Feb 08, 2013 3:07 pm
how did you get on with looking for damaged wiring,you will need to really have a good look at it sometimes its not obvious..maybe try do a continuity check
if it aint damaged... these are pump codes...and prob needs another pump...but could be knackered edc on pump
wouldnt take to much notice of p0335 as i think this will show up every time van stalls
angeleye
Postby Simtrike » Fri Feb 08, 2013 8:31 pm
Going to tempt to take off the wiring loom over the weekend but if this is not the case I have seen a pump I can get my hands on how easy is it to put on as I have been told it is part of the immobiliser and would I have to get it reprogrammed
Or is it gonna be a pain to do so
Simtrike
Postby angeleye » Fri Feb 08, 2013 9:34 pm
take it its a tddi ..pump will need virginising...or reprogrammed with the right soft ware....if its a virginised pump you will only get one go to do it ..if not done right first time will be locked...but is very easy to do just make sure battery is fully charged
if it is a tdci it wont need programming
angeleye
Postby Simtrike » Fri Feb 08, 2013 10:01 pm
Just had a look its a dura torq di if that helps
All it says on the log book is transit 280 swab td
1998cc
And we're would the best place to get it done the pump I'm looking at comes with injectors and says any thing I will need to bolt on and drive away would you know what I should get to do so
Simtrike
