fedup2 wrote:The higher specced FWD have 2 batteries.
invertor wiring..........
left is rear.
Surfunitone wrote:Also are the batteries connected via a charging relay? If I connect an inverter to the aux will it drain the main battery?
I have ps110 2.2
HARRYSPADGE wrote:Surfunitone wrote:Also are the batteries connected via a charging relay? If I connect an inverter to the aux will it drain the main battery?
I have ps110 2.2
As I understand it, when the ignition is OFF the aux and main batteries are separated by the split charge relay so that you can run auxiliary items like interior lights, radio, etc. without the risk of running the main (starter) battery flat.
So,in answer to your question, if you connect an inverter to the aux battery you will not drain the main (starter) battery.
belly wrote:fedup2 wrote:The higher specced FWD have 2 batteries.
left is rear.
Not all of them.
I have ps110 2.2
Honey monster wrote:HARRYSPADGE wrote:Surfunitone wrote:Also are the batteries connected via a charging relay? If I connect an inverter to the aux will it drain the main battery?
I have ps110 2.2
I had an ex BT Mk6 and the batterys where just connected in parallel, I take it this was a different set up than the one you mention above.
