Rob hemlock wrote:all good sound advise thanks, I am since lead to believe its a common fault on most transit models.
I have priced up from Ford TCH Dealer
@10% off retail cost for trade
£51.11 + VAT - PRV - valve
£75.00 + VAT - Fuel metering valve
so unless anyone recommends buying else where
I will order these and fit this week.
been offered use of special socket to remove metering valve
and also timing chain holding tool if I decide to remove the pump to fit on pump away from engine bay
for those that have done before would you do the job under bonnet in the engine bay or remove pump to get better access?
Users browsing this forum: alfsav, Google [Bot]
