Central locking wont work
Postby customconnects » Fri Mar 15, 2013 11:18 am
Just bought a connect that had a slight front end bump paneled it up and its starts drives etc however it doesnt lock.
Someone mentioned that it may have a locking system to unlock everything in an impact is this correct/
Can it be disabled manually or is it a dealer job?
Thanks all and fantastic Forum
customconnects
Re: Central locking wont work
Postby paul2012 » Fri Mar 15, 2013 7:12 pm
Welcome to the forum,
What year is your connect ?
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby customconnects » Fri Mar 15, 2013 11:15 pm
its a 2007/57 plate
customconnects
Postby paul2012 » Sat Mar 16, 2013 5:44 pm
The Connects 2009 onwards have the auto locking & unlocking.
When you go to lock your connect, does it lock then automatically unlock ?
paul2012
Postby customconnects » Sun Mar 17, 2013 11:33 am
Yes but only seems to be drivers door. if i lock it with the key and keep it turned for about 10 seconds it fools it into locking?
customconnects
Postby paul2012 » Tue Mar 19, 2013 1:53 pm
It sounds like one of the door locks may be faulty (lock units have door ajar switches built into them)
It tricks the central locking module into thinking that one of the doors is still open, so when you lock it will automatically unlocked again.
I had this problem with my old 2003 connect, it turned out to be the rear door lock unit was sticking .
paul2012
Postby customconnects » Tue Mar 19, 2013 5:21 pm
Ok thats great i will take it apart locks and see what its like and go from there.
Are you aware of a fault to do with airbags going off triggering doors to open?
customconnects
Postby customconnects » Wed Mar 27, 2013 1:17 pm
hi locks seem to be ok but the interior light doesnt go out when the doors are shut so im presuming that its got to be a front lock. Have checked the loom between the rear light and the rear door and that seems to be ok. stil waiting FoMoCo to get back to me with regards to the locking as there is a file on the ECU that disables the locking but they couldnt re activate the last one so does anyone know of a standalone locking system thats really good?
customconnects
Postby paul2012 » Wed Mar 27, 2013 5:31 pm
customconnects wrote:hi locks seem to be ok but the interior light doesnt go out when the doors are shut so im presuming that its got to be a front lock. Have checked the loom between the rear light and the rear door and that seems to be ok. stil waiting FoMoCo to get back to me with regards to the locking as there is a file on the ECU that disables the locking but they couldnt re activate the last one so does anyone know of a standalone locking system thats really good?
If interior lights remain on then the central locking will not work properly (Central locking module thinks a door is still open)
Has you connect got a side loading door ? ifso push against the door were the lock is & see if the interior lights go out. If they do then the door requires slight adjustment as interior light door switch is not being depressed when door in closed.
paul2012
Postby customconnects » Fri Mar 29, 2013 10:37 am
Ok Cheers paul i will try this as soon as I can
Thanks or all your help.
customconnects
Postby customconnects » Fri Mar 29, 2013 11:10 am
Hi Paul
Still no joy bud.
Thanks anyway
customconnects
Postby Graham Taylor » Fri Mar 29, 2013 11:51 am
Does this only happen with the drivers door? if so could be faulty electrics on the lock. Maybe your bump caused it and maybe just coincidence.
Graham Taylor
Postby customconnects » Fri Mar 29, 2013 12:38 pm
Hi Graham
its both front doors.
If I lock it with key in drivers door if i hold it in the lock position a couple of clicks it will lock however if i try the same in the passenger side it just keeps clicking and doesnt lock?
Thanks again to everyone for your help on this.
customconnects
Postby Graham Taylor » Fri Mar 29, 2013 1:13 pm
If it had just been the drivers door it may have been more simple but if not working on passinger side as well then probably more serious. Dont think there is an easy fix and probably need someone to checkout the whole system. Auto electrician maybe a cheaper option than main dealer (if you know a good one).
Graham Taylor
Postby customconnects » Fri Mar 29, 2013 9:20 pm
CHEERS GUYS
customconnects
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
