Mk3 Handbrake Light - on all the time
Postby rik007 » Wed Apr 03, 2013 1:46 pm
Hi, the handbrake light on my SWB 2.0l Mk3 Transit stays on all the time. Can anyone tell me where the switch is? I guess its just got stuck on, as I dont think there are any clever braking electronics on this van?
Many thanks,
Rich.
rik007
Re: Mk3 Handbrake Light - on all the time
Postby Altransit » Wed Apr 03, 2013 2:14 pm
Are you sure :?: I've never had a transit with a handbrake warning light :?
Postby Jim Archer » Wed Apr 03, 2013 3:28 pm
Check the brake fluid level.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby AlanN » Wed Apr 03, 2013 10:09 pm
Didnt have one on the MK3 that Ive ever seen, can only be fluid level or faulty float switch
Postby rik007 » Thu Apr 04, 2013 11:09 am
Doh .... what a complete idot I am!
Yes you are quite correct... its the mater cylinder fluid level which has gone down. :-(
I feel so ashamed of myself, what a plonker. Where on earth I go the hand brake issue from I've no idea.
Only thing now is that there will be a fluid leak some where and I'll bet its one of the rear cylinders ... grrr.
Thanks chaps,
Rich. :oops:
rik007
Postby Motley » Thu Apr 04, 2013 11:13 am
Just pop underneath the back end and see if the is any dampness on the brake backplates, if there is you have a leaking slave cylinder :shock:
Motley
Postby rik007 » Thu Apr 04, 2013 3:30 pm
Yup, did that at at lunch time. Sure enough, the back driver side cylinder is leaking fluid. Have ordered a new cylinder. Just got to face the joy of bleeding the brakes!
Cheers for all the help.
Rich
rik007
