MK 7) hunting/surging at idle, 2.4 ford transit
Re: MK 7) hunting/surging at idle, 2.4 ford transit
Postby belly » Sat May 18, 2013 5:21 am
I've havn't pulled my imv out yet :oops: So don't know about that, the manifold generally doesn't as the gaskets are a soft rubber type :wink: Remove them from the manifold though prior to cleaning. As for gadgets I use every job as a excuse to buy more gadgets :wink: :lol:
belly
Kaiser Chief
Postby blue estate » Sat May 18, 2013 7:35 am
belly wrote:I've havn't pulled my imv out yet :oops: So don't know about that, the manifold generally doesn't as the gaskets are a soft rubber type :wink: Remove them from the manifold though prior to cleaning. As for gadgets I use every job as a excuse to buy more gadgets :wink: :lol:
Like a 10t press :wink: :lol: :lol:
blue estate
Postby blue estate » Sat May 18, 2013 7:37 am
ake wrote:How many miles worth of gunk is that Blue :?: :?:
2010 plate at 82k :shock: and it's a 140ps
blue estate
Postby belly » Sat May 18, 2013 7:44 am
Nah no need I know a man who has one :wink: :lol:
belly
Kaiser Chief
Postby blue estate » Sat May 18, 2013 7:48 am
When you do your imv post a pic up of a gunked up 5pot manifold :D
blue estate
Postby loot » Sat May 18, 2013 8:07 am
the imv is a straight swap I think and it has an o ring which comes on the new 1, the other gaskets are blue rubber seals which I have found reusable after a little wash, the boss has a new set there that I didn't use as they came after I did the job lol he even bought a new inlet manifold after seeing the gunk in the old 1,I did offer to clean it out, didn't find out how much it was tho :(
07 350 170ps
Ids map here
loot
Postby belly » Sat May 18, 2013 8:44 am
I've already stripped it down Blue just not refitted it as I ran out of time :( My inlet manifold was only slightly gooed up but odd as it was dry so only needed a little scrape then the rest shook out like powder :shock:
belly
Kaiser Chief
Postby blue estate » Sat May 18, 2013 8:51 am
belly wrote:I've already stripped it down Blue just not refitted it as I ran out of time :( My inlet manifold was only slightly gooed up but odd as it was dry so only needed a little scrape then the rest shook out like powder :shock:
wierd :? at least 3 to5 ports should be gunky ,but it does make cleaning it easier and less messy :D
blue estate
Postby limitedblack » Sat May 18, 2013 10:59 am
Does the inlet require a new gasket each time it's cleaned ?
Happy Easter
limitedblack
Postby speedyspeedy » Sat May 18, 2013 11:03 am
ok ill get new gaskets for manifolded :wink:
speedyspeedy
Postby belly » Sat May 18, 2013 11:38 am
You can re use as long as they've not perished or gone hard :D
belly
Kaiser Chief
Postby blue estate » Sat May 18, 2013 11:39 am
One other tip don't clean your manifold in the dishwasher :shock: like one member did :roll: :lol: :lol: :lol:
blue estate
Postby limitedblack » Sat May 18, 2013 11:49 am
blue estate wrote:One other tip don't clean your manifold in the dishwasher :shock: like one member did :roll: :lol: :lol: :lol:
Don't be silly, I will use the bath :lol:
Happy Easter
limitedblack
Postby karl » Sat May 18, 2013 2:55 pm
:lol: a bath you lot are crackers my misses would go mental if I used the bath as a parts washer :lol:
karl
Tranny Lover!!!
Postby speedyspeedy » Sat May 18, 2013 5:07 pm
ok so i got the imv out and the manifold wasn't as bad a the one in the pic. but needs a little clean. :)
so ive ordered of "shebaying" imv £95 and the prv was £55 and new inlet gaskets £25. even lo the old ones don't look perished. :roll: new is always better :!:
just to let people know in the future. this was not a hard job and i love that the inlet manifold bolts stay on the manifold so u don't have to worry about
dropping them. nice one ford.
will have to white till parts come in the week and then i will book the ids in at ford :arrow: thanks again people of the transit :D
ill update soon as......
speedyspeedy
