SS11NGH wrote:Sorry mate its a 2003, i got confused with my car
SS11NGH wrote:2.5 turbo diesel
karl mcghee wrote:when you put the pump on did you get it coded to the van
sounds like the imoberliser
what the pats like doing on the dash where clock is
SS11NGH wrote:karl mcghee wrote:when you put the pump on did you get it coded to the van
The pump was not coded to the van , it was a direct replacement
All lights on dash light up as the normal ones shud wen on ignition
Altransit wrote:The pump will need to be coded using the Ford ids software, usually only a Ford dealer has this software
Was the pump changed because it wouldn't start, or has it only been not starting since the pump was changed FWD TDDi engines suffer from the pump wiring chafeing, where it crosses the starter motor
SS11NGH wrote:Diesel still gets to the injector but it wont start.
Users browsing this forum: Altransit, Google [Bot]
