Trender wrote:Hi, mine had a loud vibey rattle at mid revs and after much searching I found a stone in the exhaust shield underneath the van, I could hear the stone jumping around when tapping the shield but to remove it I had to take the shield half off.
Could be worth a few mins investigating.
ff1976 wrote:My connect has the same problem, (06 reg) sounded a bit like the baffles had gone in the exhaust so had a new one fitted but no different, then was told it was the springs in the drive plate so had a clutch kit fitted (solid flywheel on mine) and still no different, no brackets broken or heatshields rattling anywhere!
Just going to run it and not worry about it but it is frustrating!
