Brookster69 wrote:Thanks for the comments and maybe yes I should have waited ,however the base trend and limited versions were already out there prior to the sport so they should have had it sorted I have spoke to the dealership and they apologised and promise to sort out any issues, but took the shine off getting the sport, I did consider the vw sport line but at over £10 k dearer decided not too. I have had ford transits for the last 25 years and done all sorts with them from custom painting to fitting 3ltr v6 engines in them etc.i would appreciate it if anyone else out there with a new sport model has noticed if the paint finish on the front and rear body kit parts is different from the rest of the van, it's coarse, and not as glossy, have been told it's meant to be like that, but don't see why, other than the fact it's an add on, ?? Mine is in panther black .
Regards brookster69 Wirral
John Johnson wrote:Mines coarse as you describe it on the colour coding , not the bet but that's the way it is
John Johnson wrote:Shitty execution by the Turks though
