removal of wing mirror help needed
Postby feescot » Fri May 08, 2009 11:02 pm
hi can anyone tell me how i remove wing mirror on a new shape transit , i have removed caps and 1 x 8mm bolt although there are another two fixing points which seem to be rivets or something . some clown ripped my mirror off while i was parked and never even stopped , i have a new mirror and trying to fix on my own , but more difficult than i thought . cheers
feescot
Re: removal of wing mirror help needed
Postby sc_BK » Fri May 08, 2009 11:19 pm
They're fitted with shear bolts to stop people nicking them :wink:
viewtopic.php?f=5&t=43405
viewtopic.php?f=5&t=42389
viewtopic.php?f=5&t=35356
sc_BK
Postby 100 T280 » Fri May 08, 2009 11:58 pm
I remove these by breaking off the casing or remains of the casing to expose the bolt heads, drilling two small holes at 180 degrees on the head of the shear bolts, then drilling a larger hole in the centre to link these smaller holes together, then using a large flatblade screwdriver to remove. New mirror fits on using normal M6 bolts, 'cause no-one ever orders the correct ones.
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby LRN » Sat May 09, 2009 10:29 am
As said, they are fitted with shear bolts, you will need to drill them out.
When you refit with new M6 set screws, be sure to use suitable size washers
LRN
Postby coconut » Sat May 09, 2009 6:56 pm
I break the plastic and tap them round with a center punch then fit the new one with mk6 mirror bolts :wink:
coconut
Ford Technician
Postby cliff » Sun Apr 17, 2011 9:05 pm
coconut wrote:I break the plastic and tap them round with a center punch then fit the new one with mk6 mirror bolts :wink:
This worked perfect for me today, many thanks Coconut :D
57 plate 260/130 GLX in Magnum grey. Very happy so far!
cliff
GLX Posse
Postby Polly13 » Mon Dec 10, 2012 2:43 pm
So - has anyone got similar advice for a Mk 6, 2003 model?!!
Polly13
Postby angeleye » Tue Dec 11, 2012 11:10 pm
Polly13 wrote:So - has anyone got similar advice for a Mk 6, 2003 model?!!
in what way :?:
just take plastic caps (3) of mirror body undo bolts ,if you have a repeater indicator fitted this will need removing all so,any wiring for electric mirrors will need uncoupling
angeleye
Postby theloft156 » Sat Nov 16, 2013 3:20 pm
I've just changed mine after getting hit by another van last night. I DIDN'T need to use anything other than an 8mm socket on a 5cm stem - no drilling required.
The one I got from a scrapyard came off the same way.... Two minute job and nothing technical to contend with.
theloft156
Postby loot » Sat Nov 16, 2013 3:27 pm
theloft156 wrote:I've just changed mine after getting hit by another van last night. I DIDN'T need to use anything other than an 8mm socket on a 5cm stem - no drilling required.
Don't think they used shear bolts on mk6 mirrors, and ppl rarely fit them so probably a lot of mk7s that have had mirrors replaced won't have any either.
:wink:
07 350 170ps
Ids map here
loot
Postby alibabameister » Sun Nov 17, 2013 12:23 am
Replacement sheer boots available from ford just be careful as you ca now overtighten the mirror and snap the mirror xasting lug before the bolt snaps
alibabameister
Postby blue estate » Sun Nov 17, 2013 8:26 am
alibabameister wrote:Replacement sheer boots available from ford just be careful as you ca now overtighten the mirror and snap the mirror xasting lug before the bolt snaps
The dealer also sells shear bolts :wink: What are shear boots ?
blue estate
Postby mjsroofing » Sun Nov 17, 2013 10:39 am
Security bolts, the head shers off once you tighten them to stop people being able to undo them.
They also used to use them on stering columns
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby westernisles » Wed Dec 27, 2017 1:38 pm
Has anyone ever had need to remove an undamaged mirror with the two shear bolts, any tips please? Another Ford design classic...
Its a mk7 Transit Sport with electric mirrors and side flasher all built in.
westernisles
Postby Brains_transit » Wed Dec 27, 2017 1:49 pm
westernisles wrote:Has anyone ever had need to remove an undamaged mirror with the two shear bolts, any tips please? Another Ford design classic...
Drill into the centre and use a thread extractor that tightens on as you loosen it
Brains_transit
