Engine Code Location?
Re: Engine Code Location?
Postby awdriver96 » Sun Dec 22, 2013 12:50 am
That is the right book. the three cylinder running is more likely to be air in the fuel system, but the rattle/knocking is more likely to be the timing. start it up and one at a time slacken the pipe nut on each injector for a few seconds to let air out of the system and retighten each one in turn. if it runs better/ on all four thats one job done, you may have to repeat the bleeding more than once to clear all the air, bvefore it goes right. Also the tappets need checking as a lack of clearance or a pushrod jumped out will cause the same issue, then if ok go on to the timing and belt change. Any higher mileage transit, particularly with no history should have its belt changed as a matter of course as particularly the turbo versions are very sensitive to timing and all of them start far betterparticularly in cold weather with the timing spot on.
mt
awdriver96
Postby Lsecouriers » Sun Dec 22, 2013 4:45 pm
Well that's quality halfords autocentre insisted it's got. Timing chain so you can see how long I stayed there for,
I don't know what to do until new year when all garages are back open
Lsecouriers
Postby Lsecouriers » Sun Dec 22, 2013 6:01 pm
When driving back with foot on acceleratorthe black smoke coming from exhaust was unbelievable
Lsecouriers
Postby Lsecouriers » Fri Dec 27, 2013 8:38 pm
Not done much over Christmas as no where is open bought a new cAmbelt and tensioner
Lsecouriers
Postby Lsecouriers » Sun Dec 29, 2013 11:47 am
Does anyone have a diagram of the timing with the Lucas pump by any chance please
Lsecouriers
Postby Lsecouriers » Sun Dec 29, 2013 9:55 pm
Timing is not out it's fine any other ideas guys
Lsecouriers
Postby AndyG » Mon Dec 30, 2013 5:22 pm
If the timing is definitely ok :?: :o Then it has to be air getting into the system/pump :idea:
Are all the fuel connections ok and round the right way :?:
Try a direct feed into the pump from a bottle of clean diesel fuel :idea: (this bypasses all previous connections, the filter and it's housing etc.....that may be allowing air into the system)
Postby Lsecouriers » Mon Dec 30, 2013 6:59 pm
I've been paying a guy each time to check things now it's Still running the same I've got it booked in the 6th for a diagnostic which is £75 plus vat the engine light is on so hopefully the find something
Lsecouriers
Postby dieselhead123 » Mon Dec 30, 2013 8:06 pm
Did you find where the other end of the disconnected vacume line went as I asked in the PM?
There are some very clever members on here, many of whome are more than willing to assist, but to do so we need the 'full facts'.
Please, for your own sake, post up the pictures I requested in this thread, that way we can ALL help you get to the bottom of this.
Postby Lsecouriers » Mon Dec 30, 2013 8:07 pm
It plugged into the airbox
Lsecouriers
Postby AndyG » Tue Dec 31, 2013 2:08 am
Lsecouriers wrote:I've been paying a guy each time to check things now it's Still running the same I've got it booked in the 6th for a diagnostic which is £75 plus vat the engine light is on so hopefully the find something
They'll probably use a scanner/code reader that is not compatible with your EPIC system and tell you "it's the pump" :roll:
Postby Lsecouriers » Tue Dec 31, 2013 3:05 pm
Could it be my pump it was running fine on the previous engine so eliminated that
ive tried everything I could think of
does anyone on here have diagnostic for my epic system that is mobile
Lsecouriers
Postby Lsecouriers » Thu Jan 02, 2014 3:52 pm
Ive been looking over the engine and seen the pipe going to the back of the fuel filter is leaking constant
ive tried my housing from my old engine still leaking
the black smoke is unreal when accelerating
Lsecouriers
Postby fidget » Thu Jan 02, 2014 6:42 pm
check that the small bleed off pipe from the injectors has not come away from the return pipe.
follow the pipe down, it is close to the back of the engine behind the filter
and check your egr flap is opening to allow enough air in, ( if egr still in use)
my advise may not be right, but I like to give my 10p worth, and an answer even if wrong is nice to see.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
5-Speed Manual - MT75
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby Lsecouriers » Fri Jan 03, 2014 4:37 pm
Egr is moving fine
the leak is from the back of the filter on top where the housing is a pipe plugs into the back on the housing
Lsecouriers
