Transit Immobiliser
Transit Immobiliser
Postby Jonaldinho » Tue Feb 20, 2007 9:56 pm
Hi,
I have been on the search for a engine for my transit. i have found one at a salvage yard. the engine is in a stolen recovery van so no keys, but i need to hear the engine running before I take it.
I can turn it over, but it wont fire. Is there anyway of bypassing the immobilser as the electrics around the stering column have been pulled apart. there is juice pumping through, but i think the glow plugs are not heating up as i dont get the light on the dash, is this to do with the immobiliser??? The light in the headlining is flashing.
any help would be great
thanks
jon
Jonaldinho
Postby Guy88 » Tue Feb 20, 2007 10:00 pm
How old :?:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Jonaldinho » Tue Feb 20, 2007 10:02 pm
its on an 'M plate' i need it to go into my 'R 97'
Jonaldinho
Postby MarkM » Tue Feb 20, 2007 10:04 pm
Depending on the age of the Transit you are messing with they didn't have glow plugs on the later engines, mine is a '98 and no glowplugs, It may be the PATS introduction date that the glowplugs were stopped but for the exact dates another will have to give you that info. You need the key the van is supposed to have to start it, however you can bypass the PATS on the van you are trying to start, if you search on here the info together with a pic IS on here....must admit I am a little surprised that it hasn't been removed :? but it isn't so go search ;)
MarkM
Postby MrMPuk » Tue Feb 20, 2007 10:13 pm
No glow plugs on any Di, so no glow plugs from 1986 untill 2000.
Postby motorwise » Tue Feb 20, 2007 10:57 pm
a later engine will fit just take the gubbins off the back of the pump :D
glow plugs? the van/engine you have now doesn't have glow plugs none of the Di's do
http://www.motorwise.net
motorwise
Postby djswampy » Tue Feb 20, 2007 11:21 pm
I believe the Immobiliser stuff is fitted to the fuel pump. I may be wrong but there is probably a way of disconnecting it.
Mk5 LWB 190, 2.5di banana SHR, 3 seats, SLD, Twin rear doors (rusted bottoms), manual locking & windows. For sale £700, comes with replacement set of doors
djswampy
Location: Colchester. Transit: mk5, '96, 2.5di banana, lwb, semi roof, 190
Postby motorwise » Tue Feb 20, 2007 11:24 pm
djswampy wrote:I believe the Immobiliser stuff is fitted to the fuel pump. I may be wrong but there is probably a way of disconnecting it.
it's very easy to take off - you'll see when you get to it - remove the steel plate from the back - cut the soleniod wire as close to the rim module as possible - put your existing solenoid wire to the solenoid on the new pump - it's bypassed - :D
motorwise
Postby Nighthawk » Tue Feb 20, 2007 11:46 pm
If it's an M plate, it won't have a Remote Immobiliser Module (RIM) fitted
early 95's had a black plastic cover fitted over the stop solenoid, smack it off and put your own live to the solenoid and go from there.
If it's cranking over.....are you sure it's getting fuel?
Transit.........Job done
Nighthawk
Postby Jonaldinho » Wed Feb 21, 2007 11:05 am
Its turning over no probs and i have undone the fuel pipes to the head and there is plenty of juice running out when i crank it. there just isnt any firing going on.
Another question, will i have any probs putting this engine in a 97 model. I mean is there any adjustments that i need to make it work or is it just a straight swap? they both have the banana manifold everything looks the same, but is there any electrical changes in the years???
Jonaldinho
Postby gemini » Wed Feb 21, 2007 11:21 am
the engine is same the pump will be different, it will fit, there is nothing to stop it starting only the solenoid on the pump but if you are getting fuel at the injectors thats working
gemini
Postby Jonaldinho » Wed Feb 21, 2007 11:24 am
o right, so y do you think its not starting?? they said it was still running when they found it. all the wiring underneath is a mess, but i have manage to get the ignition lights on, but i dont get the little orange light come up for the glow plugs, which i now know they dont have. any ideas?
Jonaldinho
Postby unixanalyst » Wed Feb 21, 2007 1:36 pm
No glow plugs??
What manner of witchcraft is this?
How the hell did they do away with glow plugs?
unixanalyst
Postby MrMPuk » Wed Feb 21, 2007 4:39 pm
The engines are direct injection so do not require glow plugs.
Postby unixanalyst » Thu Feb 22, 2007 1:05 pm
:roll: So much to learn.
unixanalyst
