BigNeil wrote:hello
i do not have a mark6 but it is the fuse box cover not numbered to reflect the fuse box you are looking at?
Nearly every car/van i have driven has this method of diagram failing that does your manual not tell you.
having said that failing all that someone here will tell you, so have patience and no doubt the answer will come.
Mark5 fuse box under steering wheel, fuse foe cig lighter.
Smarty wrote:I will give copying it a go, if they work, I would not mind sending some copies out for the cost of postage & blank disk... (I don't mind copies but only if they are effectivley free)
Smarty.
CT1 Man wrote:We have had the same problem. Found out one of the empty fuse positions needed a fuse to get the lighter to work. Try checking all fuses or fill all the blanks
Users browsing this forum: Borry, Majestic-12 [Bot]
