MK 6) Ign Off, Oil/Ign And Handbrake Lights Staying On
Postby savi18 » Sat Aug 28, 2010 11:37 pm
Hi, yesterday switched off my Transit and the Ignition/oil/handbrake and airbag lights stayed on even thought the engine switched off ok, when i switch the ignition back on the service lights come on as normal and all goes out when started, anyone come across the before as i now have to disconnect the battery to extinguish the lights staying on.Cheers
FORD TRANSIT 2001 2.4D 350
savi18
Re: Ign Off, Oil/Ign And Handbrake Lights Staying On
Postby ake » Sun Aug 29, 2010 3:58 pm
Try unplugging the alternator and see if the lights go out
2011 Ford Mondeo 2.0 Titanium X
4 x Customs
2 x 350 MK7
7 x 260 MK7
Or is it something worse?
Postby savi18 » Mon Aug 30, 2010 9:35 am
Disconnected the alternator main feed but with no results, so seam to think it could be a relay stuck,even though i had removed the ignition relays, fault is still there, have now found the remote for the doors/alarm is not working,
You can operate the wipers/heater ect with the ign key out. this has got me stumped and dont wish to take it to Ford dealer as they are so expensive here.
More ideas please as what to check next
savi18
Postby Frag » Tue Aug 31, 2010 8:25 pm
Someone put a fuse in where it shouldn`t be :?: :idea:
Top left corner in cab box (marked radio/abs i think).
Frag
Ford Technician
Postby savi18 » Sat Sep 25, 2010 11:18 pm
Frag, you are a star mate, it was what you said top left fuse No 73(yellow), took it out and the lights when out, in my Ford owners manual it says fuse 73 is the Ciger Lighter so i must have put a fuse in by mistake when i fouud this slot empty afer checking them over, In the Haynes Ford Transit repair manaul which i have just bought it says fuse 73 is the ABS/Audio Sytem which is what you said,so the Ford Owners Manual is wrong,without you posting this advice it would have taking me ages to have sorted this out,Thanks again.
Derek (savi18)
savi18
Re: MK 6) Ign Off, Oil/Ign And Handbrake Lights Staying On
Postby Romulus » Thu Feb 27, 2014 12:17 pm
sorry to be a noob or annoisence but where is this fuse box in the cab i found one in engine bay if thats the only one, i have a 2002 ford transit diesel turbo duratora. this is my first van :D
Romulus
Postby ake » Fri Feb 28, 2014 10:33 pm
Romulus wrote:sorry to be a noob or annoisence but where is this fuse box in the cab i found one in engine bay if thats the only one, i have a 2002 ford transit diesel turbo duratora. this is my first van :D
Below the dash top cubby hole on the passenger side
4 x Customs
2 x 350 MK7
7 x 260 MK7
