90 280 to buy or not to buy
Postby vajracitta » Sun Jan 25, 2015 1:13 pm
hi all,new here,im about to buy my first transit,was after an old smiley banana but have come on a 2003 90 280 rwd manual fuel pump,i test drove it and it is a tight driving yoke,2 worries,1, the heater plug light is flashing on aand off when driving,i did search on the site and found a few answers,like perhaps injectors or perhaps egr valve or something else,forget now!!, is there a definitive answer to this problem or is it something not to worry about too much? ,secondly ,the mileage, she has done around 220 thousand miles,she was ex hire so you would think she should have been well serviced etc, the seller tells me this is nothing for these engines,but then he would if he is trying to sell it to me, oh, and the airbag light is on, not really worried about that(should i ?) that could be put out i guess, all suggestions /help much appreciated, thanks
vajracitta
Re: 90 280 to buy or not to buy
Postby bigjohnthomas » Sun Jan 25, 2015 1:28 pm
280 rwd :?
Sounds like a sack of sh*t
What are you wearing btw :?:
bigjohnthomas
Postby ake » Sun Jan 25, 2015 4:56 pm
Flashing glow plug indicates fault codes stored, fault codes need reading to diagnose
Could be throttle pedal £90
Fuel pump £650
Or lots in between
Postby bigjohnthomas » Sun Jan 25, 2015 5:42 pm
Air bag light mot fail :?:
bigjohnthomas
Postby vajracitta » Sun Jan 25, 2015 10:13 pm
thanks ake n bjt, sack o shite? bit tatty alright ,but driving good,luckily i dont care what a yoke looks like as long as its going good,and it does seem to drive well,i was chatting to a friend about the fuel pumps going on them that i had heard about,seems the manual pumps dont give as much bother as the electronic set up,is this fact?, not worried about the airbag light,she has a test as she is,what about the high mileage? would that put anyone else off,without the flashing light on i would probably take a chance on it
vajracitta
Postby bigjohnthomas » Sun Jan 25, 2015 10:32 pm
Can you not find one with no flashing lights :?:
bigjohnthomas
Postby bigjohnthomas » Sun Jan 25, 2015 10:39 pm
What do you mean manual pump ?
A tddi?
There are not many tdci mk6 s anyway
How much is it ?
Jeans slippers pipe cravat ?
bigjohnthomas
Postby vajracitta » Sun Jan 25, 2015 10:50 pm
i mean not electronic fuel injection ,you know ,the ones that give up a lot it would seem,its not too expensive,
vajracitta
Postby vajracitta » Sun Jan 25, 2015 10:51 pm
slippers,check
vajracitta
Postby ake » Sun Jan 25, 2015 10:58 pm
vajracitta wrote:i mean not electronic fuel injection ,you know ,the ones that give up a lot it would seem,its not too expensive,
It has an electronically controlled pump and mechanical injectors. If it a decent van you can change to a mechanical fuel pump, as supplied by dieselhead123, but it costs a few quid, so the van has to be worth spending money on!
Postby bigjohnthomas » Sun Jan 25, 2015 11:02 pm
might be a good idea to see what codes come up for the glow plug light before putting hand in pocket ?
Got my wellies on now in a field looking for wabbits
bigjohnthomas
Postby vajracitta » Sun Jan 25, 2015 11:05 pm
dont worry im not that mad,i wont fix nothing till its broke
vajracitta
Postby vajracitta » Sun Jan 25, 2015 11:24 pm
thanks ake, i see,so them pumps do give up too
vajracitta
Postby ake » Sun Feb 01, 2015 7:39 pm
vajracitta wrote:thanks ake, i see,so them pumps do give up too
Postby MinorMatt » Sat Apr 04, 2015 11:28 am
Early mk6 tddi pumps... they haven't got the best reputation :wink:
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Return to Buyers Guide
