fuel pump swap 1987 di / turbo engine with mechanical pump
Postby martin lewis » Thu Apr 19, 2007 5:35 pm
any ideas ? my 87 di has a cav pump and early injectors , i have been given a new 96/7 cav pump but it is designed to work with slim type injectors , it is identical apart from the fuel pipe outlets meaning no 1 cylinder outlet is in the wrong place . does anyone know if any other di fuel pipes will fit , my other thought is to move the timing round 90 deg, any thoughts appreciated . also has anyone fitted a turbo engine with a mechanical pump and still have full power , just an idea as i might convert mine,
martin lewis
Postby gemini » Thu Apr 19, 2007 5:48 pm
they didnt fit lucas cav pumps to transits in 96/7 only bosch & lucas epic for the turbo engines
gemini
Postby AndyG » Thu Apr 19, 2007 8:56 pm
:shock: Put some pictures up :idea:
We'll soon be able to tell you what pumps you have :wink:
As gemini said, the only Lucas pumps fitted from '95 were the fully electronically controlled EPIC ones that have a large 15 to 20 pin multiplug connector on the back :wink:
cav pump
Postby martin lewis » Fri Apr 20, 2007 11:51 am
i have found more info on the cav pump it is off an Ldv DI engine on a 'r' no plate it seems ldv carried on using the cav pump with the late type injectors, i have a friend with a 1990 lwb 190 which has the early pump and late injectors , i have checked the outlet positions and they are also 90deg out compared to the 1987 pump . i know the turbo only came with epic but i am thinking about fitting a turbo unit to my van and i would like to ditch the electronics , i know the Bosch mechanical pump will fit but will the power output remain OK any thoughts appreciated PS thanks for the replies
martin lewis
Postby gemini » Fri Apr 20, 2007 3:54 pm
chuck it and get a proper transit pump :wink:
gemini
cav pump fun
Postby martin lewis » Fri Apr 20, 2007 4:49 pm
me thinks you are right ! i am glad i did not fit it ,
martin lewis
Users browsing this forum: Altransit
