sus wrote:Nighthawk wrote:last time I looked, the EGR valve for the early duratorq 2.4 with the air temp switch was around 150 +vat and fitting
so a degree of arse stinging is coming your way
surely it's covered on warrenty
PMeyer wrote:wow - just found this post. My 2000 w reg van is going in tomorrow to have EGR vavle replaced. I kept getting engine management light come on and then it would clear after the van had been running for a while, if i switched it off and then on again. Can't say I've heard any noises on startup like you describe though...
here's hoping it doesn't cost too much!
psv-hgv-flt wrote:PMeyer wrote:wow - just found this post. My 2000 w reg van is going in tomorrow to have EGR vavle replaced. I kept getting engine management light come on and then it would clear after the van had been running for a while, if i switched it off and then on again. Can't say I've heard any noises on startup like you describe though...
you be best to blank it off on the 2.5 di.
ake wrote:psv-hgv-flt wrote:PMeyer wrote:wow - just found this post. My 2000 w reg van is going in tomorrow to have EGR vavle replaced. I kept getting engine management light come on and then it would clear after the van had been running for a while, if i switched it off and then on again. Can't say I've heard any noises on startup like you describe though...
That was posted in 2007, so they've probably fixed it by now
