How many Mk6 petrol/lpg are out there.
Re: How many Mk6 petrol/lpg are out there.
Postby f80chris » Sun Sep 27, 2015 11:48 pm
hi just got an 03 lpg/petrol 300 swb not in bad condition for its age it has 78000 miles on it with all mots to back it up and next to no rust chris
f80chris
Postby DL3 » Tue Nov 03, 2015 12:09 pm
I've got a tidy 2003 swb factory fitted LPG, 93,000 on the clock.
I haven't used the lpg as it hasn't worked for the last couple of years, took it into Ford and it needs a new LPG distributor and at around a grand I'll keep on with good old petrol.
DL3
Postby Rowdey » Tue Nov 03, 2015 4:24 pm
ArnoldB wrote:I Have a 2004 2.3 petrol/LPG factory fitted SWB campervan with side windows . Just been all over France and into Spain and back Petrol and LPG run well LPG will drop out when decelerating down hill and you have to stop for a few minuits and restart to get back to LPGWould like to sort this and Know more detail about which system I have got so that I can service it,Hope you can help. Arnold
Not sure if anyone got back to you, but likely to be factory Necam Koltec system. Cant say what your issue is, but contact Edward at mobile LPG servicing - http://www.mobileautomotivesandlpg.co.uk/
03 Dual Fuel MR MWB and now 66 Mk8 L2H2..
Rowdey
Postby kev sealby » Thu Nov 12, 2015 9:08 am
Postby moschops » Fri May 15, 2015 7:09 am
Forum name ................. Model..................... LPG working Y/N
1/ mealic ...................swb low roof 04..................Yes 111,000 factory fit
2/ Madmart132.............Jumbo 03 lpg.....................Yes ( But not Factory fit !!) 250,000 miles now 25 mpg Pet 17-22.5 mpg gas
3/ User774................. Swb low roof 54..................Yes 200,000 miles, london traffic so no idea of mpg. Lpg used in traffic, petrol used at speed.
4/rogerw....................Swb low roof 03 ..................None
5/ Rowdey-.................MWB/MR. 2003................... 205,000. Factory LPG with extra 90l tank.
6/ rikki19...................MWB mid roof 2001 ..............2.3 petrol 270klms....no lpg
7/ Chimplad28.............Mwb high roof, 51.................Yes,119000, Aftermarket 2.3 Petrol, Roughly 20mpg on gas
8/ Andycaravan............LWB High roof 2002...............Yes ( with rpobs ) 195k factory 18 - 20 mpg fitted extra 145 ltr tank get 750+ miles per fill
9/ injected.................MWB pick up 02....................yes, was Vialle now BRC
10/ injected................MWB pick up 02................... Yes, was Vialle, now BRC
11/ injected................MWB pick up 05....................yes, factory LPG
12/ zobby...................MWB high Roof 03.................55,500 miles, factory LPG NOT-WORKING, Petrol Perfect!!
13/ Captain Hook..........SWB Lowroof 2004.................Factory LPG
14/ Captain Hook..........SWB Lowroof 2005.................Factory LPG (Project!)
15/ Weeds...................SWB low roof 01...................No LPG 250K/Kms
16/ VGM.....................SWB Low Roof 53..................2.3 LPG, 145k LPG Not Working Fine On Petrol :?
17/ moschops...............LWB Semi-Hi roof................Petrol ok, LPG only works when engine v.hot
18/Kevin mwb Hi roof BRC after market works well about 22 mpg on gas.
Self campervan conversion that has done many miles in 30 countries.
Big end went in Estonia, but it was a lovely country to wait while it was repaired!
I love the thing, but I am never fully convinced that everything is ok with it!
kev sealby
Postby Big-al » Fri Jan 15, 2016 12:23 am
What mpg do ppl get from the 2.3 ? And what do you think about the power
Have a duel fuel Swb with head gasket gone and was thinking of changing engine for Somthing else
Big-al
Postby pj3426 » Wed Feb 10, 2016 9:07 pm
injected wrote:Not a misprint, I have three!
1/ mealic ...................swb low roof 04.................Yes 111,000 factory fit
2/ Madmart132.............Jumbo 03 lpg....................Yes ( But not Factory fit !!) 250,000 miles now 25 mpg Pet 17-22.5 mpg gas
3/ User774................. Swb low roof 54.................Yes 200,000 miles, london traffic so no idea of mpg. Lpg used in traffic, petrol used at speed.
5/ Rowdey-................. MWB/MR. 2003.................. 205,000. Factory LPG with extra 90l tank.
7/ Chimplad28..............Mwb high roof, 51................Yes,119000, Aftermarket 2.3 Petrol, Roughly 20mpg on gas
8/ Andycaravan...........LWB High roof 2002............... Yes ( with rpobs ) 195k factory 18 - 20 mpg fitted extra 145 ltr tank get 750+ miles per fill
9/ injected.................MWB pick up 02.........................yes, was Vialle now BRC
10/ injected..................MWB pick up 02..................... Yes, was Vialle, now BRC
11/ injected...................MWB pick up 05........................yes, factory LPG
12/pj3426.....................LWB High Roof 60.....................yes, not factory 80000 about 20mpg on gas. haven't used a tank of petrol yet.
pj3426
Postby captain hook » Wed Feb 10, 2016 11:22 pm
My silver 54 plate is now for sale....
Best Transit I've owned and I must have had over 100
captain hook
Postby skenk » Fri May 06, 2016 9:22 pm
SWB Medium Roof 53.................LPG works fine, but overdue a service (clean distributor etc) 94k miles and going strong
Mk6 2003 2.3 LPG/Petrol SWB MR workhorse with tweaks
Mk5 1999, died of rot RIP 2009
skenk
Postby kyah mckenzie » Tue May 31, 2016 3:48 am
i just bought one. factory fitted lpg. 03' plate. swb. low roof panel van. not sure if the lpg is running correct as never had one before. feels sometimes its using petrol aswell as gas. even though it should only be using gas
kyah mckenzie
Postby TransitBiFuel » Thu Jul 07, 2016 10:31 am
kyah mckenzie wrote:i just bought one. factory fitted lpg. 03' plate. swb. low roof panel van. not sure if the lpg is running correct as never had one before. feels sometimes its using petrol aswell as gas. even though it should only be using gas
That's not correct: the vehicle will start on unleaded and once the coolant warms up, it will switch over to LPG.
2003 Transit 280 2.3i 16V Bi-fuel SWB MR RWD
TransitBiFuel
Postby TransitBiFuel » Thu Jul 07, 2016 10:37 am
19/ TransitBiFuel...........174K miles, SWB MR RWD, factory Bi-Fuel.......Works great petrol and LPG
TransitBiFuel
Postby RockyR07 » Tue Aug 09, 2016 2:01 pm
Hello there, Richard here. Just bought a 52 plate SWB 280 Bi-fuel.......LPG seems to work so far though sometimes trips out or doesnt flick over properly. but its early days only had it a week. Has just over 100k on the clock too.
Turning it into a day van to use when going camping and the such.
RockyR07
Postby oilit » Wed Aug 10, 2016 7:27 am
i have a 2005 280 LPG just hit 80,000 had it a year - ex government. everything working fine (touch wood), could do with an insight into changing LPG filters though - ie where are they and how easy are they to change - thinking prevention better than cure here....
oilit
Postby RockyR07 » Wed Aug 10, 2016 2:42 pm
18/Kevin ....................mwb Hi roof .....................BRC after market works well about 22 mpg on gas.
19/ TransitBiFuel...........SWB MR RWD......................174K miles, , factory Bi-Fuel.......Works great petrol and LPG
20/ RockyR07...............SWB Low Roof 52................Yes, Factory LPG, 100k miles
RockyR07
Postby radad » Sun Aug 14, 2016 10:04 am
baldy1 wrote:
M4tty wrote:05 plate transit 260 swb 2.3 petrol/lpg
Done 135k lpg intermittent petrol pump gone. Starts but wont restart until cold again.
Anyone want it or anything off it before its gets scrapped??
Have you still got this Matty..and where you located price ????
Have u still got van I'm desperate for air filter box thanks
radad
