Mk3/4/5 parts
Mk3/4/5 parts
Postby MinorMatt » Wed Oct 12, 2016 1:53 pm
I need to raise some cash, so I am about to have a big clearout to raise a bit of cash and (hopefully) make some space.
I have loads of parts and bits kicking about for mk3-5 and some tools etc which will need to go too! Lots of genuine parts as well as used/pattern.
Off the top if my head
Ebersacher heaters (diesel only) - various
Mk5 front cab doors
Mk5 high top rear doors
Mk5 tailgate (needs repair but have the panel)
Various repair panels
Lock sets
Track rod ends
Ball joints,
Brake parts
Steering column
Switches
Plastic trims
Alternators
Engines
Radiators
Glass (inc side windows)
If you want anything - please ask I may well have it
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Mk3/4/5 parts
Postby Leeday » Wed Oct 12, 2016 5:41 pm
Hi Matt,
Are the lock sets new or used?
and do you have a lock set for my MK3 Transit (Drivers door, Passenger Door, Rear Tailgate and 2 side loading doors).
Many thanks,
Lee.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Re: Mk3/4/5 parts
Postby MinorMatt » Wed Oct 12, 2016 6:18 pm
Hi Lee, only new genuine mk5 lock sets
93 L GL Minibus
Re: Mk3/4/5 parts
Postby 68 beeper » Wed Oct 12, 2016 6:56 pm
Hi matt
What repair parts have you got please
68 beeper
Re: Mk3/4/5 parts
Postby Leeday » Wed Oct 12, 2016 7:27 pm
MinorMatt wrote:Hi Lee, only new genuine mk5 lock sets
Ok, Thanks Matt,
Got any Essex V6 bits?
Leeday
Re: Mk3/4/5 parts
Postby Maltesefalcon » Wed Oct 12, 2016 8:57 pm
Any Mk5 Turbo parts? :D
Maltesefalcon
Re: Mk3/4/5 parts
Postby DodgeRover » Wed Oct 12, 2016 10:12 pm
Hi do you have a drivers seat in any condition? Just need the mounting frame to avoid cutting my original up.
DodgeRover
Re: Mk3/4/5 parts
Postby MinorMatt » Thu Oct 13, 2016 8:31 am
No essex bits either...
Plenty of odds n sods of turbo parts (including a TB turbos manifold with a garrett copy on it)
No drivers seats, but have got a couple of bases (the bit that goes up and down).
93 L GL Minibus
Re: Mk3/4/5 parts
Postby DodgeRover » Thu Oct 13, 2016 1:55 pm
It's to go into my mk2, do the bases you have, have the backwards and forwards bit as well? If so will have on please
DodgeRover
Re: Mk3/4/5 parts
Postby MinorMatt » Thu Oct 13, 2016 4:16 pm
The runners, I think so.
You know the runners are a different width on the mk2 to mk4/5 and it won't bolt straight in?
93 L GL Minibus
Re: Mk3/4/5 parts
Postby FreddyVan » Thu Oct 13, 2016 8:57 pm
Hi Matt
Do you have a side repair panel.
Think you know where we are up to with our renovation lol.
FreddyVan
Re: Mk3/4/5 parts
Postby MinorMatt » Thu Oct 13, 2016 9:02 pm
Bottom side opposite the SLD? I might have one, I can't remember if I sold it...
93 L GL Minibus
Re: Mk3/4/5 parts
Postby DodgeRover » Thu Oct 13, 2016 9:07 pm
MinorMatt wrote:The runners, I think so.
Bugger was told the MK3's seats would fit a while ago and didn't expect they would have changed them in the mk4/5, any idea on the width difference and can you message me how much you want to see if its worth messing about narrowing it down to make it fit.
DodgeRover
Re: Mk3/4/5 parts
Postby MinorMatt » Thu Oct 13, 2016 9:12 pm
I doubt it to be honest, they are obviously wider!
93 L GL Minibus
Re: Mk3/4/5 parts
Postby FreddyVan » Thu Oct 13, 2016 9:50 pm
MinorMatt wrote:Bottom side opposite the SLD? I might have one, I can't remember if I sold it...
That's the one Matt, there's no rush to look as wont be going for any more work till the New Year.
Thanks.
FreddyVan
