Twin rear wheel drum removal
Postby Blitzer » Sun May 27, 2007 7:05 pm
Has anyone any advice on removing rear brake drum on a twin wheel tranni, eg bloody thing wont come off !!!!! Almost at the end of my tether and about to take large persauder (sledge hammer) to it.
Blitzer
Postby MrMPuk » Sun May 27, 2007 7:13 pm
Large hammer is how I normally do it.
Postby gemini » Sun May 27, 2007 7:18 pm
have you slackend the shoes off
gemini
Postby baby stepside » Sun May 27, 2007 7:44 pm
have you undone the nut and locking tab so that you can remove the halfshaft first?
tis eye leclair
mk5 flareside with taillift and im keeping it
baby stepside
Postby Guy88 » Sun May 27, 2007 7:50 pm
Have you took the handbrake off :oops:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby V184 » Sun May 27, 2007 9:54 pm
As above de adjust shoes let handbrake off, remove halfshaft & hub nuts & pull ! Another way is to remove wheels remove hub nuts, bolt halfshaft to hub reverse way & using it like a lever the hub/drum comes off but pulls all the old downs etc off, this is an extreme way !
V184
Postby motorwise » Sun May 27, 2007 10:33 pm
V184 wrote:As above de adjust shoes let handbrake off, remove halfshaft & hub nuts & pull ! Another way is to remove wheels remove hub nuts, bolt halfshaft to hub reverse way & using it like a lever the hub/drum comes off but pulls all the old downs etc off, this is an extreme way !
this is the way - they rarely but rarely separate from the hub like they're supposed to
http://www.motorwise.net
motorwise
Postby pony » Mon May 28, 2007 5:09 pm
i always replace the lockwasher when i have had the halfshaft out
pony
Postby baby stepside » Mon May 28, 2007 6:43 pm
pony wrote:i always replace the lockwasher when i have had the halfshaft out
just a pity it took the local dealership 24 hours to source some :?
and they wanted £10 a litre for gearbox oil :x
guess what ford dealership aint on the xmas list anymore :D
tis eye leclair
baby stepside
Postby motorwise » Mon May 28, 2007 10:27 pm
disgusting - I sell it for £9.95 a litre :wink:
motorwise
Postby jay » Mon May 28, 2007 11:29 pm
try pulling from behind the drum with a tyre lever(thats how i do mine and havent caused any damage.. I cane remember if i take the half shaft off though..I dont think u need to)
jay
Postby baby stepside » Tue May 29, 2007 9:21 am
jay wrote:try pulling from behind the drum with a tyre lever(thats how i do mine and havent caused any damage.. I cane remember if i take the half shaft off though..I dont think u need to)
i can confirm that you do need to take the halfshaft out and have first hand experiance as we had to go to a luton stranded at the side of the road with his wheels and drum 3 feet from the axle because the locknut wasnt fastened properly :oops:
tis eye leclair
baby stepside
Postby jay » Tue May 29, 2007 9:16 pm
twin wheels(mk3 defo)the drum will come off without removing the halfshaft....type 53 axle..either mine is unuasual or something but when i had a bearing go i can defo remember that i removed the drum first then the half shaft .then the big nut that hold the wheel bearing on then the hub ..
Anyone fancy stripping down a twin wheel??I would have to take a few pics but the van wont be home again till the weekend as its somewhere near wales with a driver doing a delivery.
jay
Postby pony » Tue May 29, 2007 9:21 pm
i have never known a drum seperate from the hub on a twin rear wheel axle, yes its supposed to, would make the job a lot easier too, but never seen it yet ?
pony
Postby jay » Tue May 29, 2007 9:44 pm
looks like i may have to whip a rear drum off mine just to have a look for myself...I am sure they are seperate on mine..but I could be wrong..If i do strip 1 down i will take a pic and write a how to unless someone does it before me..
jay
