Loots Red custom
Re: Loots Red custom
Postby loot » Wed Dec 21, 2016 10:04 am
There's nothing on etis Paul :-( I'm going to try and book it in, it is deffo sounding like 1 injector diesel knock or bad injector, like mk7 when cold But much worse.
Thought I'd run it without the belts, after that it'll be the engine and I'm not fixing it lol 5420 miles from new :roll:
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Wed Dec 21, 2016 10:08 am
loot wrote:There's nothing on etis Paul :-( I'm going to try and book it in, it is deffo sounding like 1 injector diesel knock or bad injector, like mk7 when cold But much worse.
Bloody Ford :roll:
Fify :)
bigjohnthomas
Postby loot » Wed Dec 21, 2016 10:12 am
Not really lol you'd have come round with 4 new injectors bjt :lol:
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Wed Dec 21, 2016 10:24 am
:lol:
bigjohnthomas
Postby paul2012 » Wed Dec 21, 2016 9:07 pm
Sorry it was a recall for injectors not TSB :oops:
R/2015/025 ENGINE MAY CUT OUT - Build Date from 12/09/2014 to 26/01/2015
A batch of fuel injectors may have been assembled incorrectly. The internal valve can fail and cause reduced fuel pressure and engine shutdown with no restart.
- Recall the vehicles that are likely to be affected and check the injectors. If the injectors of concern are fitted they will be replaced.
VINs affected NM0PXXTTGPEB80049 to WF0XXXTTGXEG58317
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Punto443 » Wed Dec 21, 2016 9:15 pm
I think loots knees knocking :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby loot » Wed Dec 21, 2016 9:36 pm
My van is prod 12/15
And vin is.WF0YXXTTGYFJ51516
Paul, is there an injector batch number or qr code or something?, thanks. :-)
07 350 170ps
Ids map here
loot
Postby paul2012 » Thu Dec 22, 2016 10:28 pm
loot wrote:My van is prod 12/15
Can't find batch number etc at the moment :(
paul2012
Postby loot » Thu Dec 22, 2016 10:44 pm
Ah that's OK :-) drove it today and i get that God awful chattering at 1 3rd throttle but when the engine is hot it doesn't do it in 4th 5th 6th :wink: (can be random)
07 350 170ps
Ids map here
loot
Postby ake » Sat Dec 24, 2016 10:19 pm
Book it in, that's what warranty is for
Postby loot » Sat Dec 24, 2016 10:34 pm
Will do, but I'm going to whip the belts off first, should knock a week off the wait. :mrgreen:
07 350 170ps
Ids map here
loot
Postby Altransit » Sat Dec 24, 2016 10:35 pm
ake wrote:Book it in, that's what warranty is for
I can't see Looty entrusting a Ford dealer with his baby :P :mrgreen: :lol:
Postby Punto443 » Sat Dec 24, 2016 10:42 pm
Is the warranty still valid on a cat c?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Altransit » Sat Dec 24, 2016 10:45 pm
I can't see why not, unless you're moaning about a bent chassis leg, or the fit of the front end panels :P :lol: :lol:
Postby bigjohnthomas » Sat Dec 24, 2016 11:24 pm
Ford won't know its had a knock will they :?:
Tell em its been good for a bit then started spooning it
bigjohnthomas
