Diagnostic Fault Codes DTCs
Postby liamwoods1989 » Thu Jan 05, 2017 12:08 am
Just looked on here how come I can't find my fault codes :-(
liamwoods1989
Re: Diagnostic Fault Codes DTCs
Postby ned » Thu Jan 05, 2017 12:19 am
[quote="liamwoods1989"]Just looked on here how come I can't find my fault codes :-(
Sent from my iPhone using Tapatalk[/quote]
What is your fault code?. N
ned
Postby liamwoods1989 » Thu Jan 05, 2017 12:21 am
[quote="nedforceone"][quote="liamwoods1989"]Just looked on here how come I can't find my fault codes :-(
What is your fault code?. N[/quote]
P2226
P089
What faults are they and how do I get rid thank you :)
liamwoods1989
Postby ned » Thu Jan 05, 2017 12:34 am
P2226 barometric pressure circuit
P0089 fuel pressure relief valve (prv)
You have most probably got a blown prv, search prv and scv it is very comon on mk7's to have to replace the scv and prv and have pump n pilot learns done. N
ned
Postby liamwoods1989 » Thu Jan 05, 2017 12:41 am
[quote="nedforceone"]P2226 barometric pressure circuit
You have most probably got a blown prv, search prv and scv it is very comon on mk7's to have to replace the scv and prv and have pump n pilot learns done. N[/quote]
Ok thank you mate will look now :)
liamwoods1989
Postby liamwoods1989 » Thu Jan 05, 2017 12:57 am
[quote="liamwoods1989"][quote="nedforceone"]P2226 barometric pressure circuit
I was just looking I had the light come on a few weeks back and Busseys had it in and put a new scv valve on and I seemed to have sorted the problem. Since then I have had it remapped and in since then the light has come back on. When looking at then valves it stats what horse power the van is mine being 100 horse but mapped to 140. Would this affect that part ? Do I need a valve for 140 horse power now or is it not that simple cherrs
liamwoods1989
Postby ned » Thu Jan 05, 2017 12:58 am
viewtopic.php?f=5&t=72477#p613990
This might help. N
ned
Postby ned » Thu Jan 05, 2017 1:04 am
P
Er don't know best start a new post in mk6/7 third generation then the clever buggers can assist you more then I can. N
ned
Postby liamwoods1989 » Thu Jan 05, 2017 1:05 am
nedforceone wrote:[quote="liamwoods1989"
P
Er don't know best start a new post in mk6/7 third generation then the clever buggers can assist you more then I can. N[/quote] ok mate thanks for the help that last link is helpful though :)
liamwoods1989
Users browsing this forum: Google Adsense [Bot], metalworker0
