smiley MT75 5spd gearbox --> fastidious replacement advice
Postby 97transit2.5D » Wed Jan 11, 2017 10:55 pm
Hi guys, wanting to spend wisely but am fastidious in refurbishing transit gearbox.
option 1: get a gearbox company to refresh my gearbox in a 190 HB smiley 2.5 non turb 1997 ....use parts from another one plus two others i have found
ASSUMPTION: the lengths of other MT75 gearboxes that come from similar year transits ,and mounting points the same, for all the gearboxes taken from the other (ie smileys with SWB or LWB, 150 or 190 or what have you??)
perhaps coupler end is larger or different but can be replaced,yeah?
My gearbox works but planning for when synchro or cones stop functioning, as for the past 12 years been hard to put it into 1st gear ( cone or sychro wearing problem)
and it has a crack in the bell housing conneted to the rear main on the engine.
Can anyone recommend mt75 transit bearings sets (not chinese thanks) and clutch plate sets that are good quality.
option 2: getting a fully refurbished one on a swap basis where supposedly they use good quality seals and bearings.but is more expensive option.
97transit2.5D
Re: smiley MT75 5spd gearbox --> fastidious replacement advi
Postby Jim Archer » Thu Jan 12, 2017 8:51 am
Is 1st gear difficult to engage all the time? If only when gearbox is cold - wrong oil, use MT75. If all the time - you have either a dragging clutch or a spigot bearing gone tight.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby V184 » Thu Jan 12, 2017 6:16 pm
Option 2 dearer ? when you have got to repair/replace cracked casing :?
V184
Postby 97transit2.5D » Fri Jan 13, 2017 3:00 am
yep but I can take off the cracked bell housing and have it replaced with one of three bell housings I have from complete/partial of three MT75 gearboxes i have
thanks about the spigot bearing info...1st gear...i think it does it most times especially when change too quickly ...the oil is correct as it was changed by ford here in chch,nz and they put in somekind of additive
yep dragging clutch....would also be good reason to have the whole gear box refurbished incl new clutch.....
I am also in the process of getting a kit together via ebay with SKF bearings and quality seals.
do you know of the best clutch types to fit to the smiley? i found this for the 190,2.5 mine is DEC 1996
http://www.ebay.co.uk/itm/DriveTorque-S ... SwBLlVMTDS
do you need any other parts???? during the gearing box replacement..... is there a rubber boot or seal to be replaced when have taken off gear box?? on diff??
97transit2.5D
Postby Mfr » Fri Jan 13, 2017 9:31 am
you may well need a new rear crank seal and gasket. I did mine when I swapped the gearbox. Luk clutches are good I have the uprated 265mm version on mine.
Mfr
Postby V184 » Fri Jan 13, 2017 10:52 am
I would buy the "Ford clutch" which i think is made by Sachs ? check the clutch forks ok as well :wink:
V184
Postby 97transit2.5D » Fri Jan 20, 2017 10:37 am
cheers guys....
97transit2.5D
Postby Mfr » Fri Jan 20, 2017 8:04 pm
Sorry forgot to say in the PM, yes SVO clutch fits MT75 fine.
Mfr
