Hi fellas.
I'm thinking about fitting a second battery with Sterling charger etc. but it just seems like a lot of money.
Can someone tell me the benefits please?
Thankee
moley551 wrote:As you said the only way that gives a reliable system would be with the battery to battery charger, I've given up with the smart relay split charging system it doesn't work anything like previous vans, I now just charge the leisure battery overnight as I think connecting it to the van actually lowers it's charge level. I'm going to look at solar panels for my next van.
mistericeman wrote:moley551 wrote:As you said the only way that gives a reliable system would be with the battery to battery charger, I've given up with the smart relay split charging system it doesn't work anything like previous vans, I now just charge the leisure battery overnight as I think connecting it to the van actually lowers it's charge level. I'm going to look at solar panels for my next van.
Not had a single issue with the Durite VSR.... simple to fit an reliable....
it also allows the vehicle battery to be charged by the solar panels once the leisure batteries are fully charged.
moley551 wrote:mistericeman wrote:moley551 wrote:As you said the only way that gives a reliable system would be with the battery to battery charger, I've given up with the smart relay split charging system it doesn't work anything like previous vans, I now just charge the leisure battery overnight as I think connecting it to the van actually lowers it's charge level. I'm going to look at solar panels for my next van.
Has your van got smart regenerative charging? the VSR worked fine in my previous vans but it has always been weak in the Custom.
mistericeman wrote:moley551 wrote:moley551 wrote:As you said the only way that gives a reliable system would be with the battery to battery charger, I've given up with the smart relay split charging system it doesn't work anything like previous vans, I now just charge the leisure battery overnight as I think connecting it to the van actually lowers it's charge level. I'm going to look at solar panels for my next van.
AHHH nail on the head there ....VSR's dont like "Smart" alternators.
