Which ply-lining kit for LWB DCIV
Postby LongTallPaul » Mon Apr 17, 2017 9:38 pm
Hi All, Newbie here.
Have picked up a 2014 LWB DCIV that is in need of ply-lining but I'm a little confused about the kits available over on eBay. All the ads I've seen talk about SWB or LWB but nothing seems to highlight a DCIV. My question is which kit is right for a LWB DCIV? My thinking is that the correct one is the SWB kit. Is this right?
Cheers!
LongTallPaul
Re: Which ply-lining kit for LWB DCIV
Postby yasser » Tue Apr 18, 2017 7:41 am
LongTallPaul wrote:Hi All, Newbie here.
Cheers!
Where abouts are you?
310 DCiV L2 Limited 155
yasser
Postby LongTallPaul » Tue Apr 18, 2017 8:26 am
Glastonbury, Somerset
LongTallPaul
Postby yasser » Tue Apr 18, 2017 10:58 am
well that's a bit to far to come... I was going to say that you can use my templates but as i'm in the Lake district its a bit of a trek but if you are planning on coming up this way at all they are for a L2 H1 DCiV and you are quite welcome to us them.
yasser
Postby LongTallPaul » Wed Apr 19, 2017 10:21 am
Thank you for the offer. I needed another excuse to come to the Lake District :) I'll let you know if I'm in the area.
LongTallPaul
Postby Jamesg5206 » Wed Apr 19, 2017 1:46 pm
Have you tried TGS in Bristol. I'm not sure if they will do supply only and maybe expensive.
Transit Custom 125 Trend SWB Panther Black 2014-2017 Transit Tourneo Custom 185 Agate Black Titanium X LWB 2019-
Transit Tourneo Custom 155 Titanium LWB Panther Back 2015-2019
Transit Custom 170 Limited SWB Shadow Black 2017-
Jamesg5206
Postby yasser » Wed Apr 19, 2017 1:54 pm
Are you looking to ply line for work or are you looking to carpet line as well?
yasser
Postby Nederbelg » Wed Apr 19, 2017 10:25 pm
Did you already consider the use of Plastic (PP) liner instead of Plywood? Lighter (in weight) and more atractive colour than Plywood.
Gr Nederbelg
Nederbelg
Postby loot » Fri Apr 21, 2017 12:15 am
I'm a bit confused here? If you have a dciv then don't you have panels fitted where you would want to fit the ply?
Are you after ply side panels? Floor?
Custom load length is L1(swb) L2(lwb) isn't it so that should follow, also have you got single sld or twin?
Did you have factory dciv with seats, interior trim and bulkhead or just someone fitted seats into a van?
07 350 170ps
Ids map here
loot
Postby Spinal Tap » Fri Apr 21, 2017 4:33 pm
loot wrote:I'm a bit confused here? If you have a dciv then don't you have panels fitted where you would want to fit the ply?
Mines a DCIV and has ply lining in the rear load area, I assume that's where Paul means.
To Paul:
Try using Crew Cab rather than DCIV when googling, it does bring up a few hits.
It might be easier though just to ring the ply lining companies and ask.
Spinal Tap
Postby loot » Fri Apr 21, 2017 5:21 pm
Ah cheers, i like learning too :mrgreen:
07 350 170ps
Ids map here
loot
Postby Spinal Tap » Fri Apr 21, 2017 5:29 pm
:D :D :D :D :D
Spinal Tap
Postby LongTallPaul » Mon Apr 24, 2017 12:20 am
Thanks for all the tips - I hadn't come across TGS before but will enquire.
It is a factory DCIV and I'm looking to line it for work, so carpet really isn't going to be an option.
@Nederbelg - I hadn't consider plastic but will look into it as that might be easier to sweep out. Had a plastic liner on my old Navara.
I'll post an update on how I get on.
BTW - appreciate all the contributors on this forum. It has been really useful as a new Transit owner.
LongTallPaul
Postby Nederbelg » Thu Apr 27, 2017 9:25 pm
here is a Link to a german Site which sell's such liners, so you can see how they look like:
http://www.rahloff.com/Ford/Custom/Cust ... :3263.html
It must be possible to buy such liners in the UK too, but i don't have a link off that. :cry:
Gr Nederbelg
Nederbelg
Return to Transit Custom
