MK6 2.4 5 speed, Rear diff 5.13
Postby wicklabilly » Tue Aug 08, 2017 6:54 am
Hello all. Me transit tipper tows an 850kg wood chipper, lots of kit and usually 2/3 men plus anything up to 2 Ton on the rear.
It has a 5.13 rear diff and even when I haven't got the chipper on the tow bar she struggles as the gearing feels to high and I have to give it 'max beans' and murder the clutch and ultimately the gearbox to get her moving along.
If I want to fit a slightly lower ratio rear diff to give me better acceleration and tractability which one should I go for bearing in mind mine is currently a 5.13 ? Thanks for the help :)
2002 Yella Transit Crew cab Tipper. T350 120 bhp Fairly clean and literally no chassis rust. 2011 MK7 crew cab Transit tipper. T350 115PS Euro 4
wicklabilly
Re: MK6 2.4 5 speed, Rear diff 5.13
Postby dumper » Tue Aug 08, 2017 7:03 am
I think you need a bigger truck you are well overloaded
Postby Jim Archer » Tue Aug 08, 2017 10:33 am
Yup, reckon it's trying to tell you something before VOSA does.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby richgold » Tue Aug 08, 2017 5:17 pm
2 ton on the rear + 850kg on tow?????
How on earth do you stop?
Jesus christ.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby spinna » Tue Aug 08, 2017 5:38 pm
As others have said. You need bigger truck and I'm pretty sure you already have lowest ratio diff available
Sent from my SM-G925F using Tapatalk
2009 MK7 T330, 2.4TDCI 100 SWB.
1994 Nissan Patrol Y60 4.2 diesel
2004 Vauxhall Vectra SRi 1.9cdti
spinna
Postby wicklabilly » Wed Aug 09, 2017 7:00 am
richgold wrote:2 ton on the rear + 850kg on tow?????
Jesus christ.
Hello, yes i'm deffo overloaded. I always tip out on site or close by to where I have been working unless it's a small load of wood chip and i'm close to home, in that case I can tow the chipper as well without to much stress on the drive train. Due to the areas where I work (pretty extreme hills and narrow lanes) I need lower ratios and i'm fairly certain there is a diff that's more suitable then the stock 5.13 that's currently fitted?
Thanks.
wicklabilly
Postby ake » Wed Aug 09, 2017 7:08 am
There is a 5.88 diff ratio as well for mk 6
Postby wicklabilly » Thu Aug 10, 2017 6:28 am
[quote="ake"]There is a 5.88 diff ratio as well for mk 6[/quote
Yet again thank you Ake. I seem to remember someone saying the lower spec engines like the 90hp have lower ratio diffs. I used to drive a 5 speed,100HP MK7 that had the 'towing diff' and it was an astounding vehicle, so tractable and nothing fazed it.
wicklabilly
Postby wicklabilly » Wed Aug 16, 2017 10:21 am
ake wrote:There is a 5.88 diff ratio as well for mk 6
Just getting a price on a crown wheel and pinion from a 5.88 diff, apparently that's all I need to retrofit to my existing diff to lower the gearing. Thanks for all the help and advice on this one folks. :)
wicklabilly
Postby MK7 user » Wed Aug 16, 2017 2:50 pm
wicklabilly wrote: I need lower ratios and i'm fairly certain there is a diff that's more suitable then the stock 5.13 that's currently fitted? Thanks.
wicklabilly wrote: I used to drive a 5 speed,100HP MK7 that had the 'towing diff' and it was an astounding vehicle, so tractable and nothing fazed it.
Lol....you are saying that the the Mk7 with a higher ratio (5.11 - the towing diff) is astounding & the Mk6 with a lower ratio (5.13) is over geared. :mrgreen:
The Mk7 RWD are all fitted with Dana rear axles so you have the option to change the crown wheel & pinion in the existing axle. :)
The Mk6 uses different axles....the 5.88 crown wheel & pinion you mention above won't fit your existing diff housing - ya need to change the whole axle. :x
Additionally....no offence intended, but you can only drop so much on a Mk6 that's not worth much to start with....personal opinions being what they are I would be looking at a remapped 115~140ps Mk7 with a 6-speed box & a 4.27 diff....you'll have higher torque with a remap, lower ratio gears with a 6-speed box & retain the option of dropping down to a standard 5.11 crown wheel & pinion if you decide that a 4.27 is anything other than perfect. :idea:
No Squire, not just any van....it has to be a Mk7 (VM.1) :D
MK7 user
Location: Grim HQ in the parish of Aston Nr the Great Hall
Postby Transitpartsuk » Wed Aug 16, 2017 7:48 pm
As the previous person said the crown wheel and pinion on the 5.88 axle will be larger than the 5.13 or 4.63. Bearings will be different as well as halfshafts etc. On the Dana axle the drums are different as well. So I don't think its a simple job. All the Dana axles were 6 speeds (on the MK6) as well so will need to change pripshaft coupling etc.
Transitpartsuk
Registered Trader
Registered Trader
Postby MK7 user » Thu Aug 17, 2017 1:15 pm
As the previous person said....the drums are different on the 5.88 axle, when they reach there service limit you may need to sell a kidney to buy a new pair. :x
MK7 user
Postby wicklabilly » Sat Aug 19, 2017 1:22 pm
Hello there, I have no idea really! I don't know very much about diff ratios but all I was saying is the MK7 I drove was only 100ps and had a 5 speed box, and was very low geared as it was used for towing and cud fly along nicely with over 1.5 ton of woodchip on the back whilst towing an 850kg trailer. I didn't actually look at the tag on the diff so I can't confirm what ratio it was, (but I will ask for the details from Ford ETIS so we can establish the diff ratio it used). It was a truly awesome van to drive.
My MK6 is 120ps but I do wonder if the engine 'is tired' as I have cleaned out the inlet and blanked the EGR, new fuel filter and air filter, oil and oil filter and it hasn't made much of a difference in terms of performance, wonder if my timing is spot on or could it be that it is out by a tooth or 2 maybe?? I suspect a new fuel pump and or injectors might restore some performance. Thank you to both You and TPUK for explaining about the differences between the MK6 and MK7 axle differences as I assumed they were identical.
So is 5.13 the lowest ration available for my MK6 then ??
wicklabilly
Postby wicklabilly » Sat Aug 19, 2017 10:31 pm
just found this which relates to that MK7 i loved driving so much.
Transit 2006-2014, Duratorq TDCI 2.4 (100PS), Frozen White
VIN Number: WF0NXXTTFN8C84164
Registration Number: NH08LXU
First Registration Date: 29.07.2008
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 01.05.2008
Vehicle Line: Transit 2006-2014
Cab Style: Double Cab - Goods Vehicle
Series: 1.7-350L Series
Engine: Duratorq TDCI 2.4 (100PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.11
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
wicklabilly
Postby MK7 user » Sun Aug 20, 2017 1:39 am
Alright dude. :)
Yeah....on your axle a 5.13 is the lowest they went.
I would guess a double cab tipper will be +2.6 tonne depending on the spec of the tipper, but a 120 shouldn't hang about unladen....if it feels as if it's at a snails pace I would guess there is more wrong with it than just fair wear & tear.
Do you know anything about it's history :?:
MK7 user
