Mk7 flip key
Re: Mk7 flip key
Postby Thequeenscheese » Fri Sep 08, 2017 8:59 pm
The long grey oblong is the transponder and I do t think that will be an issue, it's the distance for the wireless charging that bothers me more as I don't know where or which bit it is.
2.2 tdci T280
Thequeenscheese
Re: Mk7 flip key
Postby ned » Fri Sep 08, 2017 9:01 pm
Its Jaguars fault I only have a little silver nob :lol: its not much use with my broken van through :roll: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Mk7 flip key
Postby ned » Fri Sep 08, 2017 9:04 pm
I've got an idea, buy it try it, if it works wonderbra :lol: if it doesn't you've wasted 6 sovs. N
ned
Re: Mk7 flip key
Postby Thequeenscheese » Fri Sep 08, 2017 9:23 pm
nedforceone wrote:I've got an idea, buy it try it, if it works wonderbra :lol: if it doesn't you've wasted 6 sovs. N
Already ordered
2.2 tdci T280
Thequeenscheese
Re: Mk7 flip key
Postby Thequeenscheese » Thu Sep 21, 2017 7:04 pm
Boom shakalakala..
A couple of hours worth of fiddling and a tiny bit of fettling left plus a bit of sealing and...I need to take it back to the key cutter though as its snagging in the barrel but works perfect and seems to recharge ok
2.2 tdci T280
Thequeenscheese
Re: Mk7 flip key
Postby Thequeenscheese » Thu Sep 21, 2017 7:12 pm
Also bit of Usefull info if you didn't know, the chap who cut the key gave me the key code for it so now I have it if I loose all keys, prob worth asking for it if you get one cut or just want it I forget his method but it was pretty easy to figure out ..
2.2 tdci T280
Thequeenscheese
Re: Mk7 flip key
Postby ned » Thu Sep 21, 2017 7:18 pm
You do know you are going to have to do a "how to" post for this now, in the how to section.
Do all the buttons works?. N
ned
Re: Mk7 flip key
Postby Thequeenscheese » Thu Sep 21, 2017 7:28 pm
Yes all work fine, the hardest bit (and I still have to fettle this) is getting them to line up and now I know they work I'll need to glue the pcb into the housing so it doesn't move inside when fastened and sealed.
The how to tbh is easy cut most of the perturbing locating plastic away from the inside including the locating screw tube at the back (which is shy the rear of the key will need to be glued or sealed together), file away unnecessary pcb where needed and the white plastic housing making sure not to file into any chips or crucial bits if your careful you may not need to glue the pcb in the housing but I filed a little too much off at one end and it moves now unalighning the buttons but other than that it easy peasy I did it on my knee with rudimentary kit in half darkness.
It still amazes me that there isn't any official ones out there tbh.
2.2 tdci T280
Thequeenscheese
Re: Mk7 flip key
Postby Punto443 » Thu Sep 21, 2017 7:29 pm
Mk7 has already been done a while ago I'm afraid :D
viewtopic.php?f=27&t=152781
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: Mk7 flip key
Postby Thequeenscheese » Thu Sep 21, 2017 8:03 pm
That's about right, I'm glad no one pointed me to that thread when I asked lol..
2.2 tdci T280
Thequeenscheese
Re: Mk7 flip key
Postby EDDY99 » Fri Sep 22, 2017 7:40 am
How to read a tibbe key
MK 7 Transit 2006 (56) 2.4L Duratorq-TDCi (100PS) Series 1.7-350L
EDDY99
